Parametrized FEM study
Brucesc2
Postby Brucesc2 » Wed Aug 10, 2016 12:25 pm
Im looking to create a parametrized study using the FEM module. My first and only idea to do this is to use the Macro editor and create a script somehow. A number of questions arose because it sounded simpler than it was:
1. How to activate the Analysis?
2. How to find the methods to start the simulation?
3. How to keep and store the results, then how to show the results?
I just started using the FEM Module and the python script but somewhat it confuses me and I am stuck how to find methods for the GUI objects, by using dir, but it only gives the "common view-object methods" as I see it.
Although this could be a more "python" aimed topic, it has still somewhat with fundamental FEM studies that professional uses for design evaluations.
This is the original post, I add the comments from PrzemoF:
I'd suggest to start a new topic and take a look at the test for FEM wb [1]. It does full analysis except instead running CalculiX makes a mock calculations.
[1] https://github.com/FreeCAD/FreeCAD/blob ... TestFem.py
Best Regards,
Markus
bernd
Re: Parametrized FEM study
Postby bernd » Wed Aug 10, 2016 2:14 pm
How to solve CalculiX analysis by python. This are just the same defs called by the gui buttons.
Start FreeCAD --> change to start wb --> load 3D FEM example
import FemGui
FemGui.setActiveAnalysis(FreeCAD.ActiveDocument.Analysis)
import FemToolsCcx
fea = FemToolsCcx.FemToolsCcx()
fea.update_objects()
fea.check_prerequisites() # a string is returned, the string should be empty
fea.reset_all()
fea.run()
fea.load_results()
bernd
Postby bernd » Wed Aug 10, 2016 2:36 pm
How to make the 3D example by python ...
delete the FEM objects ...
App.ActiveDocument.removeObject("MechanicalMaterial")
App.ActiveDocument.removeObject("FemConstraintForce")
App.ActiveDocument.removeObject("FemConstraintFixed")
App.ActiveDocument.removeObject("CalculiX")
App.ActiveDocument.removeObject("CalculiX_static_results")
App.ActiveDocument.removeObject("Analysis")
recreate the objects by python ...
doc = App.ActiveDocument
# analysis
import FemAnalysis
FemAnalysis.makeFemAnalysis('Analysis')
# solver
solver_object = FemSolverCalculix.makeFemSolverCalculix('CalculiX')
solver_object.GeometricalNonlinearity = 'linear'
solver_object.SteadyState = True
solver_object.MatrixSolverType = 'default'
solver_object.IterationsControlParameterTimeUse = False
doc.Analysis.Member = doc.Analysis.Member + [solver_object]
# material
import MechanicalMaterial
material_object = MechanicalMaterial.makeMechanicalMaterial('MechanicalMaterial')
mat = material_object.Material
mat['Name'] = "Steel-Generic"
mat['YoungsModulus'] = "210000 MPa"
mat['PoissonRatio'] = "0.30"
mat['Density'] = "7900 kg/m^3"
material_object.Material = mat
doc.Analysis.Member = doc.Analysis.Member + [material_object]
# fixed_constraint
fixed_constraint = doc.addObject("Fem::ConstraintFixed", "FemConstraintFixed")
fixed_constraint.References = [(doc.Box, "Face1")]
doc.Analysis.Member = doc.Analysis.Member + [fixed_constraint]
# force_constraint
force_constraint = doc.addObject("Fem::ConstraintForce", "FemConstraintForce")
force_constraint.References = [(doc.Box, "Face2")]
force_constraint.Force = 9000000.0
force_constraint.Direction = (doc.Box, ["Edge5"])
force_constraint.Reversed = True
doc.Analysis.Member = doc.Analysis.Member + [force_constraint]
# mesh
doc.Analysis.Member = doc.Analysis.Member + [doc.Box_Mesh]
# recompute doc
doc.recompute()
how to solve see last post ... result will be the same as before ...
Brucesc2
Postby Brucesc2 » Sun Aug 14, 2016 1:52 pm
Thanks, could you give me an example of how to find the python method from the code so that I could find them myself? Or is it all the code as supplied in that git-version available in the python console?
Im thinking also to include how to make the mesh in python, and in the end maybe a simple GUI.
BR
Markus
bernd
Postby bernd » Mon Aug 15, 2016 5:18 am
Brucesc2 wrote:Thanks, could you give me an example of how to find the python method from the code so that I could find them myself?
- check the module TestFem.py in source code, https://github.com/FreeCAD/FreeCAD/blob ... TestFem.py
- while working with FreeCAD Gui watch the python console. Lot's of commands are printed
- ask here for help.
- actually all the commands should be on the wiki at the commands linked on FEM Module but most of them are missing.
- The commands linked on Draft Module and Arch Module are great examples how it should look like ...
bernd
Postby bernd » Mon Aug 15, 2016 5:26 am
to print the supported FEM document object types you could use:
App.newDocument()
module = 'Fem'
FreeCADGui.doCommand('import ' + module)
for s in sorted(App.ActiveDocument.supportedTypes()):
    if s.startswith(module):
        print s
>>> import Fem
...     if s.startswith(module):
...         print s
Fem::Constraint
Fem::ConstraintBearing
Fem::ConstraintContact
Fem::ConstraintDisplacement
Fem::ConstraintFluidBoundary
Fem::ConstraintGear
Fem::ConstraintHeatflux
Fem::ConstraintInitialTemperature
Fem::ConstraintPlaneRotation
Fem::ConstraintPressure
Fem::ConstraintPulley
Fem::ConstraintTemperature
Fem::DocumentObject
Fem::FeaturePython
Fem::FemAnalysis
Fem::FemAnalysisPython
Fem::FemMeshObject
Fem::FemMeshShapeNetgenObject
Fem::FemMeshShapeObject
Fem::FemPostClipFilter
Fem::FemPostCutFilter
Fem::FemPostFilter
Fem::FemPostFunction
Fem::FemPostFunctionProvider
Fem::FemPostObject
Fem::FemPostPipeline
Fem::FemPostPlaneFunction
Fem::FemPostScalarClipFilter
Fem::FemPostSphereFunction
Fem::FemPostWarpVectorFilter
Fem::FemResultObject
Fem::FemSetElementsObject
Fem::FemSetFacesObject
Fem::FemSetGeometryObject
Fem::FemSetNodesObject
Fem::FemSetObject
Fem::FemSolverObject
Fem::FemSolverObjectPython
To get the supported attributes of an document object:
- select the object in tree browser
- in selection view right click on it --> to python console --> you have it saved in obj
- in python console just do a:
obj.PropertiesList
for the solver object you get
>>> obj = App.getDocument("Unnamed2").getObject("CalculiX")
>>> obj.PropertiesList
['AnalysisType', 'EigenmodeHighLimit', 'EigenmodeLowLimit', 'EigenmodesCount', 'ExpressionEngine', 'GeometricalNonlinearity', 'IterationsControlParameterCutb', 'IterationsControlParameterIter', 'IterationsControlParameterTimeUse', 'IterationsMaximum', 'Label', 'MatrixSolverType', 'Proxy', 'SolverType', 'SteadyState', 'TimeEnd', 'TimeInitialStep', 'WorkingDir']
How to set an property see one of the posts before.
hope this helps, bernd
bernd
Postby bernd » Mon Aug 15, 2016 5:29 am
Brucesc2 wrote:Im thinking also to include how to make the mesh in python, and in the end maybe a simple GUI.
FEM Mesh
Brucesc2
Postby Brucesc2 » Tue Aug 16, 2016 9:44 pm
Hey,
Is there anyway to access the netgen object to start the execute command? How can I set the shape for example? I can only access the ViewProviderFemMesh and not its not really needed for my application, but Im thinking to develop a more user friendly approach as well and see if I could contribute. The attached example can be used, the test example uses a solid cone and mesh (named cone_mesh) as input (the solid cone needs to be selected when running the script)
https://github.com/FreeCAD/FreeCAD/blob ... Object.cpp
BR
Markus
test.txt
(3.4 KiB) Downloaded 80 times
bernd
Postby bernd » Wed Aug 17, 2016 10:25 am
try:
import Part
box = Part.makeBox(10,10,10)
box_obj = App.ActiveDocument.addObject('Part::Box', 'MyBox')
femmesh_obj = App.ActiveDocument.addObject('Fem::FemMeshShapeNetgenObject', 'MyMesh')
femmesh_obj.Shape = box_obj
femmesh_obj.MaxSize = 1
femmesh_obj.FemMesh
ickby
Postby ickby » Wed Aug 17, 2016 10:41 am
Hm it seems it would be nice to have a "python only" workflow for all FEM calculations, without having any document objects. Like the Mesh object which allows pure python handling, the same would be nice for material, constraitns, calculation, postproccesing etc.
Normally in FreeCAD every functionality is provided in a python interface of some kind (like FEM:Mesh object or Part::Shape) and the document objects only wrap those python functionality. I think one day we should do that for FEM too.
