3 Node Beam Elements not yet supported
Site Admin
Re: 3 Node Beam Elements not yet supported
Postby wmayer » Mon Dec 12, 2016 11:44 am
git commit 5466568 fixes all the reported problems.
makkemal
Postby makkemal » Mon Dec 12, 2016 12:07 pm
Some enhancement of beam sections allowing user to select circular and pipe beam sections
https://github.com/makkemal/FreeCAD/tree/Beam_sections
bernd
Postby bernd » Mon Dec 12, 2016 5:03 pm
wmayer wrote:git commit 5466568 fixes all the reported problems.
brilliant
bernd
Postby bernd » Mon Dec 12, 2016 5:05 pm
makkemal wrote:Some enhancement of beam sections allowing user to select circular and pipe beam sections
included in my dev branch https://github.com/berndhahnebach/FreeC ... meshregion. I have a few minor things but I'm gone fix them right above yours, if you guys don't mind.
bernd
Postby bernd » Mon Dec 12, 2016 5:21 pm
brilliant
Ahh one thing still remains. We've found a bug in unv reader ...
# 10 node tetrahedron --> tetra10 ###############
import Fem
tetra10 = Fem.FemMesh()  # a FEM mesh
tetra10.addNode( 6, 12, 18, 1)  # some nodes
tetra10.addNode( 0,  0, 18, 2)
tetra10.addNode(12,  0, 18, 3)
tetra10.addNode( 6,  6,  0, 4)
tetra10.addNode( 3,  6, 18, 5)
tetra10.addNode( 6,  0, 18, 6)
tetra10.addNode( 9,  6, 18, 7)
tetra10.addNode( 6,  9,  9, 8)
tetra10.addNode( 3,  3,  9, 9)
tetra10.addNode( 9,  3,  9,10)
tetra10.addVolume([1, 2, 3, 4, 5, 6, 7, 8, 9, 10], 88)  # a volume with ID: 88
tetra10.Volumes
obj = App.ActiveDocument.addObject("Fem::FemMeshObject","tetra10")
obj.FemMesh = tetra10
obj.FemMesh.Volumes
meshpath = u"/home/hugo/Desktop/femmesh.unv"
tetra10.write(meshpath)
mesh = Fem.read(meshpath)
mesh.Volumes
and even worse, because unv is used in FreeCAD to save FEMmeshes to fcstd files
doc = App.newDocument('mydoc')
import Fem
tetra10.Volumes
obj = doc.addObject("Fem::FemMeshObject","tetra10")
obj.FemMesh.Volumes
doc.saveAs(u"/home/hugo/Desktop/femmesh.fcstd")
App.closeDocument("mydoc")
FreeCAD.open(u"/home/hugo/Desktop/femmesh.fcstd")
App.ActiveDocument.tetra10.FemMesh.Volumes
after reopen the FreeCAD document the FemMesh has changed because the element number of the volume is not 88 but 1 instead.
Site Admin
Postby wmayer » Mon Dec 12, 2016 5:49 pm
Yes, that's the issue I found. But fixing smesh stuff is not my realm.
makkemal
Postby makkemal » Tue Dec 13, 2016 5:37 am
@Bernd
Yes go for it, we are just picking up some low hanging fruit in terms of functionality
bernd
Postby bernd » Tue Dec 13, 2016 9:30 am
IMHO we should not use radio buttons to choose the cross sections. We should go for a combobox and change the task panel depended on the chosen section type. Similar to Part --> create primitives.
For my first material refernce shape implementation I used such a task panel ui. https://github.com/berndhahnebach/FreeC ... aterial.ui You can open it in a simple ui - viewer and change the shapes of the model combo box
bernd
Postby bernd » Tue Dec 13, 2016 12:18 pm
try attached one in an ui viewer ...
remove .txt
TaskPanelFemBeamSection.ui.txt
(13.47 KiB) Downloaded 90 times
bernd
Postby bernd » Tue Dec 13, 2016 4:20 pm
@makkemal:
try https://github.com/berndhahnebach/FreeC ... meshregion
the section type is not yet updated with the combo box from task panel, means the type has to be chosen in property editor, but all length values can be edited in task panel already.
bernd
