Applying a torque using FORCE and TRANSFORM constraints
Re: Applying a torque using FORCE and TRANSFORM constraints
What should i say? I also though (think) that is the case, but only can inform what i can see.
Greetings
user1234
Greetings
user1234
Minimum example.
For the simplest case (short shaft, no bending), to get the tension of a torque is:
Method A: 24 segments, every force in the rectangular lever direction. The problem on plane faces is, that you can not add force transformation tools. Seems OK. Tresca (shear) around 18.5 N/mm². I will add a method B with transformation.
Greetings
user1234
D = 200.0 #mm
d = 180.0 #mm
T = 10000.0 #Nm
WP = math.pi / 16.0 * ( D ** 4.0 - d ** 4 ) / D
tau = T * 1000.0 / WP
print ( "D = " + str( D ) + " mm" )
print ( "d = " + str( d ) + " mm" )
print ( "T = " + str( T ) + " Nm" )
print ( "WP = " + str( WP ) + " mm³")
print ( "tau = " + str( tau ) + " N/mm²" ) #18.5N/mm²
Greetings
user1234
So, now with transformation tools. Never used that before, because i never get that working. but with the example from the OP it works. The transformation tools only works, when the force is set in the Y-direction. In X not. Also you can only transform forces on radial surfaces, not on plane surfaces, also when they have radial boundaries.
Greetings
user1234
The shear stress is also OK.Greetings
user1234
Just saying that the displacements on both examples are also on point.
while phi is
On example A
FEM = 45.8640µm --> 0.026278degree
classic calculated = 0.026263degree
On example B (length is shorter)
FEM = 45.3326µm --> 0.025973degree
classic calculated = 0.024950degree
Greetings
user1234
import math
D = 200.0 # mm
d = 180.0 # mm
T = 10000.0 # Nm
l = 200.0 # mm
ny = 0.3 # 1
E = 210000.0 # N/mm²
G = 1.0 / ( 2.0 * ( 1.0 + ny ) ) * E
IP = math.pi / 32.0 * ( D ** 4.0 - d ** 4.0 )
phi = T * 1000.0 * l / ( G * IP )
print ( "G = " + str( G ) + " N/mm²" )
print ( "IP = " + str( IP ) + " N/mm⁴" )
print ( "phi = " + str( phi ) + " rad")
print ( "phi = " + str( phi * 180 / math.pi ) + " degree" )
phi = asin( displacement / D)
Greetings
user1234
The question if there are useful for you? You reactivate this thread, so what do you need?
In the usefulness i see some points:
- the transform only works if the force before is set in the Y direction (if the axis is in Z direction)
- you can not transform the face side of a diameter which leads me to an other question
I think that set a torque on a face side is not less important (clutches, flanges, heavy-walled shafts, .....). I am pretty sure, that the transforms only works on cylinder faces, because the force on every node is constant and on a face side of a cylinder not ( F(x,y) ). So here a some questions:
- do the TRANSFORM command feed the force direction up in Calulix after a iteration, because the vector of the force is every iteration a little bit an other because of the displacement (very small but there). In my example A this is clearly not the case. For very long shaft (10m) this can be important. The rule in the machine construction is a max. displacement of ~ 0.25° / 1m .
- if i a able to get a algorithm to get a array (list) of the nodes and their forces for a torque replacement, does it blow up the inp file?
Sorry for the noob questions.
Greetings
user1234
Greetings
user1234
ATM we do not have such example in the FEM GUI examples. Thus I reactivated the topic because there might be someone who can help to do the math for the first example of the topic. I was not able to do them. The firste example is coded already but just not merged into the main FreeCAD. https://github.com/berndhahnebach/FreeC ... _torque.py IMHO for this we should use a example for which we are able to calculate the result with mechanical formulas.
I may have a look at your example too. But for this I would have need to write the code to generate the example by Python.
The load of the example is way to high to get serious results. 500Nm for a 1 mm thick pipe with 10mm outer diameter is way to high. I would set the load in Line 141 from:
to
. If i do that, i get good displacements results.
0.03340 calculated
0.0333980 FEM.
But i want also control the shear stress. What is the easiest function to get the tau(z)? I want to see if the curve fits.
Greetings
user1234
force_constraint.Force = 100000.0
force_constraint.Force = 2500.0
0.03340 calculated
0.0333980 FEM.
D = 10.0 # mm
d = 8.0 # mm
z = 50.0 # mm
T = 12.5 # Nm
ny = 0.3 # 1
Wp = math.pi / 16.0 * ( D ** 4.0 - d ** 4 ) / D
Ip = math.pi / 32.0 * ( D ** 4.0 - d ** 4.0 )
phi = T * 1000.0 * z / ( G * Ip * 2 )
print ( "--------------------------------------------------\n" )
print ( "classical distributed load function" )
print ( "phi = " + str( phi ) + " rad" )
print ( "phi = " + str( phi * 180.0 / math.pi ) + " °" )
print ( "dis = " + str( math.sin( phi ) * D / 2.0 ) + " mm" )
print ( "\n--------------------------------------------------\n\n" )
# calculated through steps
steps = 1000 # 1
dz = z / steps # mm
dT = T * 1000.0 / z # Mm/mm
dphi = []
phi = 0.0
#z = []
for i in range( steps ):
#z.append( dz * i + 0.5 * dz )
dphi.append( dT * dz * ( steps - i ) * dz / ( G * Ip ) )
phi = sum( dphi )
print ( "--------------------------------------------------" )
print ( "finite step load" )
phi = 0.006675100852350753 rad
phi = 0.38245510666387666 °
dis = 0.03337525641040786 mm
finite step load
phi = 0.006681775953203104 rad
phi = 0.3828375617705405 °
dis = 0.033408631170372884 mm
Greetings
user1234
oh yeah and stress too. Before I got 7606 MPa. Even the best of Scottys material would break ...user1234 wrote: ↑Thu Jul 08, 2021 10:32 pm The load of the example is way to high to get serious results. 500Nm for a 1 mm thick pipe with 10mm outer diameter is way to high. I would set the load in Line 141 from:toCode: Select all
. If i do that, i get good displacements results.Code: Select all
would you edit your python code to calculate the deformation? It misses a "import math" at the beginning. Just if some beginner would test the code he might not know what to do.
cheers bernd
