contact constraint example
bernd
Re: contact constraint example
Postby bernd » Sun Jan 29, 2017 6:38 pm
makkemal wrote:I don't have a problem this model runs.
ccx 2.10
OS: Ubuntu 16.04.1 LTS
Would you test with this ccx http://packages.ubuntu.com/xenial/calculix-ccx In a fresh xenial install with the ccx from xenial I get an error too if I run the input file
makkemal
Postby makkemal » Sun Jan 29, 2017 6:49 pm
With that version of ccx I also get a problem
bernd
Postby bernd » Sun Jan 29, 2017 7:29 pm
Thanks michael. I got in contact with the package maintainer. Bernd
for reference:
https://packages.debian.org/stretch/calculix-ccx
bernd
Postby bernd » Tue Jan 31, 2017 6:37 am
it strange ... if I change the following lines
*STEP
*CONTROLS, PARAMETERS=TIME INCREMENTATION
4,8,9,200,10,400,,200,,
0.25,0.5,0.75,0.85,,,1.5,
*STATIC, DIRECT
0.1, 1.0
to
*STEP
*STATIC
**0.1, 1.0
after hundreds of iterations I get the 10 results but the max deformation in y is 47 mm not 29 mm. But I do not have a glue what is different.
http://feacluster.com/CalculiX/ccx_2.11 ... de287.html
http://feacluster.com/CalculiX/ccx_2.11 ... de214.html
Jee-Bee
Postby Jee-Bee » Tue Jan 31, 2017 7:02 am
maybe something to ask at their group mail
https://groups.yahoo.com/neo/groups/calculix/info
bernd
Postby bernd » Tue Jan 31, 2017 7:05 am
Jee-Bee wrote:maybe something to ask at their group mail
At the moment I am in contact with the package maintainer of calculix-ccx in ubuntu and debian. Since it seams package related. Only these packages have the problems.
Jee-Bee
Postby Jee-Bee » Tue Jan 31, 2017 7:48 am
check thanks
bernd
Postby bernd » Fri Jan 31, 2020 10:18 pm
ccx professionals wanted :geek:
Is there someone out there who gets absolute displacement ca 29.77 mm with the file attached?
contact-example-udated2.fcstd
(140.73 KiB) Downloaded 7 times
UR_
Postby UR_ » Sat Feb 01, 2020 9:08 am
object
CalculiXccxTools_fandaL vs. CalculiXccxTools_std
Screenshot 003.png (22.28 KiB) Viewed 173 times
Screenshot 004.png (22.03 KiB) Viewed 173 times
using:
ccx_2.16_pardiso_dynamic.exe
bernd
Postby bernd » Sat Feb 01, 2020 3:38 pm
