Problem with UNV-Mesh-reading
ulrich1a
Postby ulrich1a » Fri Feb 10, 2017 10:18 pm
I am having a problem with FEM-meshes made with Gmsh. It did work well for quite some time, but now I am getting this mesh for a cube.
I could not find the commit that cause this.
The mesh is created fine with Gmsh, but shows up this wrong way in FreeCAD.
It does work with: 70049dac4b6b5c416694f64182452e69565246b5 I just picked this commit for a test.
It failed with: 72d2349429cdba6beeaec93658ccd2315baa1d14
Any ideas?
Edit: It seems to be this commit, that causes the problem: 6c2a7b479fc8cbd821e1d10df94dee2057f0ca92
issue #0002891: Sketching impossible, Type.Error Exception
Ulrich
bernd
Re: Problem with UNV-Mesh-reading
Postby bernd » Sat Feb 11, 2017 9:40 am
for reference
- 70049dac4b6b5c416694f64182452e69565246b5 --> git commit 70049da
- 72d2349429cdba6beeaec93658ccd2315baa1d14 --> git commit 72d2349
- 6c2a7b479fc8cbd821e1d10df94dee2057f0ca92 --> git commit 6c2a7b4
bernd
Postby bernd » Sat Feb 11, 2017 9:47 am
works for me with:
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.10064 (Git)
Build type: Unknown
Hash: d7ed8c4383f394f64dd9314eefa00efae02fb32f
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
does the GMSH mesh object of FreeCAD works for you? This uses unv too. Would you post a file to test with.
ulrich1a
Postby ulrich1a » Sat Feb 11, 2017 1:56 pm
The problem shows up at making the mesh with the Gmsh-button. Here is an example. Importing a mesh does work!
Ulrich
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.17.10065 (Git)
Branch: Rueck6
Hash: 1cec205531828b44156dff7b655d72ee10119529
Qt version: 4.8.6
OCC version: 7.1.0
Box_failed_mesh.fcstd
(66.61 KiB) Downloaded 15 times
bernd
Postby bernd » Sat Feb 11, 2017 2:21 pm
GMSH mesh button works for me too as well as meshing your box. If you use the GMSH mesh button in FreeCAD and watch the report console there are some informations printed about the files involved. You can see the brep, the geo and the unvfile which where involved in the process. Try to use them manually. Run GMSH manually, with the provided geo, import the created unv manually ...
BTW: you where not using master branch. you are one commit ahead master
ulrich1a
Postby ulrich1a » Sat Feb 11, 2017 3:22 pm
bernd wrote:BTW: you where not using master branch. you are one commit ahead master
I had to add a few VTK-modules in order to compile FreeCAD on my system. So I am always one commit ahead.
I made a test regarding locale. It gives the following output on my system
ulrich@Pauline:~/Sourcen/FreeCAD/FreeCAD_0.16/bin$ locale
LANG=de_DE.utf8
LANGUAGE=
LC_CTYPE="de_DE.utf8"
LC_NUMERIC="de_DE.utf8"
LC_TIME="de_DE.utf8"
LC_COLLATE="de_DE.utf8"
LC_MONETARY="de_DE.utf8"
LC_MESSAGES="de_DE.utf8"
LC_PAPER="de_DE.utf8"
LC_NAME="de_DE.utf8"
LC_ADDRESS="de_DE.utf8"
LC_TELEPHONE="de_DE.utf8"
LC_MEASUREMENT="de_DE.utf8"
LC_IDENTIFICATION="de_DE.utf8"
LC_ALL=
At setting LC_NUMERIC to "C" Gmsh works again on my system.
ulrich@Pauline:~/Sourcen/FreeCAD/Build_0.17/bin$ locale
LANG=de_DE.utf8
LANGUAGE=
LC_NUMERIC=C
LC_ALL=
It seems the identified commit breaks Gmsh support on my Debian. Can you post your locale setting?
Ulrich
HoWil
Postby HoWil » Sat Feb 11, 2017 4:25 pm
I face the same problem with freshly build master (using bernd's script, deleted everything before).
$ locale
LANG=de_AT.UTF-8
LANGUAGE=de_AT:de
LC_CTYPE="de_AT.UTF-8"
LC_NUMERIC=de_AT.UTF-8
LC_TIME=de_AT.UTF-8
LC_COLLATE="de_AT.UTF-8"
LC_MONETARY=de_AT.UTF-8
LC_MESSAGES="de_AT.UTF-8"
LC_PAPER=de_AT.UTF-8
LC_NAME=de_AT.UTF-8
LC_ADDRESS=de_AT.UTF-8
LC_TELEPHONE=de_AT.UTF-8
LC_MEASUREMENT=de_AT.UTF-8
LC_IDENTIFICATION=de_AT.UTF-8
LC_ALL=
I also noticed that usually the solid which is meshed is automatically hidden and the mesh is shown instead but it does not happen.
Is it maybe related to gmsh? I use the one provided in the repository of Ubuntu 16.04.1
$ gmsh -version
2.10.1
OS: Ubuntu 16.04.1 LTS
Build type: Unknown
Python version: 2.7.12
OCC version: 7.0.0
ulrich1a
Postby ulrich1a » Sat Feb 11, 2017 4:41 pm
HoWil wrote:Is it maybe related to gmsh?
No, it is related to commit - 6c2a7b479fc8cbd821e1d10df94dee2057f0ca92 --> http://github.com/FreeCAD/FreeCAD/commit/6c2a7b4
This changes internal setting of LC_NUMERIC. Try to type into the console
 export LC_NUMERIC="C"
and then run FreeCAD from this console. The meshing works than again for me.
Ulrich
HoWil
Postby HoWil » Sat Feb 11, 2017 5:12 pm
Yeap Ulrich,
it did the trick :D
ulrich1a wrote:Code: Select all
Thx,
HoWil
Site Admin
Postby wmayer » Sat Feb 11, 2017 6:38 pm
See also this thread: https://forum.freecadweb.org/viewtopic. ... 37#p158962
The note in the Qt docssays that
On Unix/Linux Qt is configured to use the system locale settings by default. This can cause a conflict when using POSIX functions, for instance, when converting between data types such as floats and strings, since the notation may differ between locales. To get around this problem, call the POSIX function setlocale(LC_NUMERIC,"C") right after initializing QApplication, QGuiApplication or QCoreApplication to reset the locale that is used for number formatting to "C"-locale.
And all what I did is to move the call
from the main() to the runApplication() after the QApplication is created.
The effect is that now the decimal separator again is a point (i.e. C locale) and not eventually a comma (e.g. for de_DE.UTF-8) which is the desired behaviour.
Now what is the problem with gmsh? Does it fail while loading existing files? If yes can you check if there is comma as decimal separator in floating numbers?
