OpenSees, the Open System for Earthquake Engineering Simulation
Re: OpenSees, the Open System for Earthquake Engineering Simulation
Postby bernd » Fri Feb 28, 2020 11:04 am
shahram10715 wrote:
Fri Feb 28, 2020 10:06 am
ebrahim raeyat wrote:
Wed Feb 26, 2020 9:22 pm
thanks to openseespy, we can write opensees input file in python format and benefit from all of python library!
https://openseespydoc.readthedocs.io/en/latest/
Its a good choice but we must consider that this package is not published open source yet.
If it is not OpenSource I will not do any dev in my spare time in this regard. I would recommend to use the TCL interface than. Made a issue to bring light in the darkness ... https://github.com/OpenSeesPy-pip/opens ... /issues/11
Postby Kunda1 » Fri Feb 28, 2020 2:32 pm
shahram10715 wrote:
Fri Feb 28, 2020 10:03 am
Kunda1 wrote:
Thu Feb 27, 2020 2:29 pm
Maybe a conda repository ?
I'm not quite sure but I think it is dedicated to python packages only.
See https://github.com/FreeCAD/FreeCAD_Cond ... /README.md
Postby bernd » Fri Feb 28, 2020 3:28 pm
according to a post on the issue OpenSeesPy is opensource and included in main opensees.
Would be good if one you you both opensees guys would test this OpenSeesPy and could give some feedback. Python is the languarge we speak, thus it would be cool to use this one.
cheers bernd
ebrahim raeyat
Postby ebrahim raeyat » Fri Feb 28, 2020 4:35 pm
cheers bernd
yes, it is in main source of opensees:
i will try to prepare an example for openseespy, these are available:
https://openseespydoc.readthedocs.io/en ... mples.html
kkremitzki
Postby kkremitzki » Fri Feb 28, 2020 11:25 pm
OpenSees' license
The Regents grants permission, without fee and without a written license agreement, for (a) use,
reproduction, modification, and distribution of this software and its documentation by educational,
research, and non-profit entities for noncommercial purposes only;
is not open source because of its non-commercial restriction, failing #6 of The Open Source Definition, "6. No Discrimination Against Fields of Endeavor". It's source-available. With its current license it will never, for example, be able to be distributed in Debian.
ebrahim raeyat
Postby ebrahim raeyat » Sat Feb 29, 2020 8:43 am
according to this issue on openseespy-pip i changed the name of element, but new question:
node numbering for C3D20 element is different than 20NodeBrick element in opensees, i map those node number, but it gives me this error:
Twenty_Node_Brick::Jacobian3d - Non-positive Jacobian: -1.73472e-11
    0   -8.260282e-01   -8.260282e-01   -8.260282e-01    2.261895e-01
    1   -3.936492e-01   -2.745967e-02   -2.745967e-02   -1.087298e-01
    2   -1.274597e-01   -1.274597e-01    6.350833e-03   -3.127017e-02
    3   -2.745967e-02   -3.936492e-01   -2.745967e-02   -1.087298e-01
    4   -2.745967e-02   -2.745967e-02   -3.936492e-01   -1.087298e-01
    5   -1.274597e-01    6.350833e-03   -1.274597e-01   -3.127017e-02
    6   -2.602817e-02   -2.602817e-02   -2.602817e-02   -6.189500e-03
    7    6.350833e-03   -1.274597e-01   -1.274597e-01   -3.127017e-02
    8    1.219677e+00   -1.774597e-01   -1.774597e-01    3.149193e-01
    9    1.774597e-01    1.549193e-01   -2.254033e-02    4.000000e-02
   10    1.549193e-01    1.774597e-01   -2.254033e-02    4.000000e-02
   11   -1.774597e-01    1.219677e+00   -1.774597e-01    3.149193e-01
   12    1.549193e-01   -2.254033e-02    1.774597e-01    4.000000e-02
   13    2.254033e-02    1.967734e-02    2.254033e-02    5.080666e-03
   14    1.967734e-02    2.254033e-02    2.254033e-02    5.080666e-03
   15   -2.254033e-02    1.549193e-01    1.774597e-01    4.000000e-02
   16   -1.774597e-01   -1.774597e-01    1.219677e+00    3.149193e-01
   17    1.774597e-01   -2.254033e-02    1.549193e-01    4.000000e-02
   18    2.254033e-02    2.254033e-02    1.967734e-02    5.080666e-03
   19   -2.254033e-02    1.774597e-01    1.549193e-01    4.000000e-02
now, my question is: what is principle axis in C3D20 element?
i examin it in three state, first no change between them, one for as is in picture and another for axis that i assume, but in those state gives me that error. this is my python script that convert node numbering:
inpfile = open('/home/ebi/Box_Mesh001.inp', 'r')
line = inpfile.readline()
while not line.startswith("** Volume elements"):
    continue
inpfile.readline()
with open('/home/ebi/opensees/openseespy/element.tcl', 'w') as pyfile:
    while not line.startswith('*'):
        try:
            num, *nodes = line.split(',')[:-1]
            nodes2 = line.split(',')[:-1]
            n = nodes + nodes2
            maps = [7, 8, 5, 6, 3, 4, 1, 2, 15, 16, 13, 14, 11, 12, 9, 10, 19, 20, 17, 18]
            node = ''.join(f'{n[i - 1]} ' for i in maps)
#             node = ''.join(f'{i} ' for i in n)
            pyfile.write(f"element 20NodeBrick {num} {node}  1\n")
        except:
            break
Postby bernd » Sat Feb 29, 2020 10:29 am
have you read FEM_Mesh and FEM_Mesh_CalculiX they may help
Postby bernd » Sat Feb 29, 2020 10:31 am
OpenSees' license
Thanks reminding about this!
ebrahim raeyat
Postby ebrahim raeyat » Sat Feb 29, 2020 6:17 pm
oops, i mistake this section in convert .inp file to opensees format:
xyz[-1] = xyz[-1].rstrip("\n")
last coordinate z, have "\n" character, this is now work, i will prepare .tcl and .py file soon.
thanks @bernd
ebrahim raeyat
Postby ebrahim raeyat » Sun Mar 01, 2020 3:34 am
this is my first attempt to visualize 3D cantilever beam with openseespy, it's cool:
