OpenSees, the Open System for Earthquake Engineering Simulation
bernd
Re: OpenSees, the Open System for Earthquake Engineering Simulation
Post by bernd »
Would you like to add it generally to a specific material? Means all the time you use this material or you open this material card the shear modulus is given.
Would you like to add it for a material which is part of a FreeCAD FEM analysis file?
ebrahim raeyat
Post by ebrahim raeyat »
bernd wrote: Tue Apr 28, 2020 10:26 am
yes, I want to obtain it in my analysis, I don't want to change it generally in Freecad.
bernd
Post by bernd »
works great here ...
- start FreeCAD
- open a material inside a analysis
- edit shear modulus with material editor (as shown in your screen)
- access material parameter in Python
example attached, open file run code:
App.ActiveDocument.MechanicalSolidMaterial.Material['ShearModulus']
'300 kPa'
femanalysis_material_with_shearmodulus1.FCStd
(7.87 KiB) Downloaded 57 times
ebrahim raeyat
bernd wrote: Mon Apr 27, 2020 3:49 am great. How about code it in Python add it to femexamples package, and make a small unit test out of it ?
I made it, everything is ok, but when I want to create an input file, it takes me this error:
  File "/home/ebi/freecads/freecad-build/Mod/Fem/femsolver/opensees/writer.py", line 131, in write_opensees_input_file
    self.get_element_sets_material_and_femelement_type()
  File "/home/ebi/freecads/freecad-build/Mod/Fem/femsolver/writerbase.py", line 501, in get_element_sets_material_and_femelement_type
    self.get_element_rotation1D_elements()
  File "/home/ebi/freecads/freecad-build/Mod/Fem/femsolver/writerbase.py", line 416, in get_element_rotation1D_elements
    self.theshape
AttributeError: 'FemInputWriterOpenSees' object has no attribute 'theshape'
If I delete the mesh and create it manually it works.
frame3D.FCStd
(28.93 KiB) Downloaded 65 times
bernd
Post by bernd »
I may know what the problem is. Do you have a branch to tes with? Your opensees branch is nor uptodate?!
ebrahim raeyat
bernd wrote: Wed Apr 29, 2020 5:49 pm I may know what the problem is. Do you have a branch to tes with? Your opensees branch is nor uptodate?!
I must commit it to my opensees branch? I sent you a PR, but let me ask you a question:
how can I work on two branches simultaneously, for example when I working on adding example, I want also to work on adding shell element to opensees, how can I do that? if I checkout one branch that did not complete it's changes, git take me an error. thanks.
bernd
Post by bernd »
if you work on two new features use two branches. To checkout another branch you need to commit your changes.
Cherry-pick or a rebase can be used to move changes from branch to the other.
BTW: commit often with les changes.
Post by Kunda1 »
bernd wrote: Thu Apr 30, 2020 4:24 am if you work on two new features use two branches. To checkout another branch you need to commit your changes.
It's also possible to git stash (if you're not ready to commit)
ebrahim raeyat
Kunda1 wrote: Thu Apr 30, 2020 12:07 pm
thanks, I will examine it.
ebrahim raeyat
can you detect the problem?
