3D line plot
bernd
3D line plot
Postby bernd » Wed Mar 01, 2017 2:38 pm
Does someone know what is best to archive 3D line plots as they are used to show sectional forces on line analysises.
- is there may be something in some other FreeCAD workbench?
- does VTK/paraview support such post processing
- does some other python library support such plots
see the picture for example:
yorik
Site Admin
Re: 3D line plot
Postby yorik » Thu Mar 02, 2017 1:28 pm
If it was me, I think I would write a kind of wrapper library with a couple of convenience methods (plotCurve(), plotGraph() things like that), and inside, discretize everything and do everything with coin/pivy... There is also the plot workbench that has stuff to print curves, but I'm not sure if they render in the 3d view or not. In any case you should have a look at it first
It would be a killer if we get such graphs in freecad!
ian.rees
Re: 3D line plot
Postby ian.rees » Fri Mar 03, 2017 9:11 pm
If there's not an existing solution, it might be worth considering implementing one as a matplotlib backend.
ulrich1a
Re: 3D line plot
Postby ulrich1a » Mon Mar 06, 2017 3:55 pm
Chris_G made some similar plots in FreeCAD to show the curvature of a B-Spline. Maybe his script can be used as a template to show the force and moment data. See here: https://forum.freecadweb.org/viewtopic.php?f=22&t=15313
Ulrich
HoWil
Re: 3D line plot
Postby HoWil » Mon Mar 06, 2017 4:27 pm
ian.rees wrote:If there's not an existing solution, it might be worth considering implementing one as a matplotlib backend.
Matplotlib can nicely generate .svg wich could be placed equivalent to https://forum.freecadweb.org/viewtopic.php?f=10&t=20989
The advantage of matplotlib is having axis, grid, labels,.. Already available on a high level.
BR
Howil
bernd
Re: 3D line plot
Postby bernd » Mon Mar 06, 2017 7:01 pm
ulrich1a wrote:Chris_G made some similar plots in FreeCAD to show the curvature of a B-Spline. Maybe his script can be used as a template to show the force and moment data. See here: https://forum.freecadweb.org/viewtopic.php?f=22&t=15313
That's the stuff we need :D
bernd
Re: 3D line plot
I have been searching the Internet but could not find how to create such plots by matplotlib.
bernd
Re: 3D line plot
Postby bernd » Mon Mar 06, 2017 7:07 pm
yorik wrote:It would be a killer if we get such graphs in freecad!
At some point in the future we just need such post processing. issue #2950
HoWil
Re: 3D line plot
Postby HoWil » Mon Mar 06, 2017 8:35 pm
Hi Bernd,
I have tried to produce such a plot but partly failed at the first attempt .... see https://forum.freecadweb.org/viewtopic. ... 45#p163745
Here my code for a small test macro ... maybe it is anyhow helpfull.
# -*- coding: utf-8 -*-
# creating a plot similar to the one at http://matplotlib.org/examples/pylab_examples/fill_between_demo.html
import matplotlib.pyplot as plt
import numpy as np
x = np.arange(0.0, 2, 0.01)
y1 = np.sin(2*np.pi*x)
y2 = 1.2*np.sin(4*np.pi*x)
# now fill between y1 and y2 where a logical condition is met.  Note
# this is different than calling
#   fill_between(x[where], y1[where],y2[where]
# because of edge effects over multiple contiguous regions.
fig = plt.figure(figsize=(100/25.4, 100/25.4))
ax = fig.add_subplot(211)
ax1 = fig.add_subplot(212)
ax.plot(x, y1, x, y2, color='black')
#ax.fill_between(x, y1, y2, where=y2 >= y1, facecolor='green', interpolate=True)
#ax.fill_between(x, y1, y2, where=y2 <= y1, facecolor='red', interpolate=True)
ax.set_title('fill between where')
#ax.set_axis_bgcolor(None)
# Test support for masked arrays.
y2 = np.ma.masked_greater(y2, 1.0)
ax1.plot(x, y1, x, y2, color='black')
#ax1.fill_between(x, y1, y2, where=y2 >= y1, facecolor='green', interpolate=True)
#ax1.fill_between(x, y1, y2, where=y2 <= y1, facecolor='red', interpolate=True)
ax1.set_title('Now regions with y2>1 are masked')
#ax1.set_axis_bgcolor(None)
ax.patch.set_visible(False)
ax1.patch.set_visible(False)
fig.patch.set_visible(False)
fig.savefig('/tmp/output.svg')
# creating a box in FC
import FreeCAD
import Part
App.newDocument("Unnamed")
App.ActiveDocument.addObject("Part::Box","Box")
App.ActiveDocument.ActiveObject.Label = "Cube"
FreeCAD.getDocument("Unnamed").getObject("Box").Length = '100 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Width = '100 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Height = '100 mm'
Gui.SendMsgToActiveView("ViewFit")
# importing the plot into FC as described here https://forum.freecadweb.org/viewtopic.php?f=10&t=20989
from pivy import coin
sg = Gui.ActiveDocument.ActiveView.getSceneGraph()
svg = coin.SoTexture2()
svg.filename = '/tmp/output.svg'
box = coin.SoVRMLBox()
box.size = (100,100,0)
imagePos = coin.SoTransform()
imagePos.translation.setValue([50,50,100])
imagePos.rotation = coin.SbRotation(0,0,0,0)
image = coin.SoSeparator()
image.addChild(imagePos)
image.addChild(svg)
image.addChild(box)
sg.addChild(image)
BR
HoWil
cnirbhay
Re: 3D line plot
Postby cnirbhay » Wed Mar 08, 2017 9:32 am
Which software did you use to get these results? STAAD Pro also gives such post processing results with support reactions, deflections, SFD & BMD. It would be really great to get such analytical details in FreeCAD too. :-)
I guess results from Calculix in FEM workbench can be somehow used to obtain such details.
