FEM object types
Re: FEM object types
Fantastic, it works:
Next I will prepare a more practical example
Thanks Bernd
Thanks Bernd
And what a pleasing result with some mesh refinement ...
wow cool !
Take into account your sandwich example may not work because of a design error I made. The mesh is written with the following preference: https://github.com/berndhahnebach/FreeC ... .cpp#L1184 May be this does not write the faces for your sandwich example. I did not know about such model technicals when I did the femmixedmeshes code.
In preparation for a practical application of mixed meshes I hit a speed bump with line elements:
I can't see anything wrong with element 1, but the INP file does have a few strange looking entries for *BEAM SECTION:
This is a vertical beam, so would it have anything to do with problems reported earlier for vertical beams?
I attach the FC file for reference:
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13452 (Git)
Build type: None
Hash: 34633c144de9133c1f9aeb7da783f369cae9bfaf
Python version: 2.7.12
OCC version: 7.1.0
Build type: None
OCC version: 7.1.0
problem confirmed: I will have a look, see https://forum.freecadweb.org/viewtopic.php?f=18&t=27891 It should work on rectangular sections !
I tried, but it didn't. I will have another look.
look at this funny eigen frequency ...
as a workaround change in inputfile the following line
to
*Element, TYPE=B32, ELSET=Eedges
*Element, TYPE=B32R, ELSET=Eedges
That's definitely not right as the first eigen-mode
PS: Is this with reactungular beams?
What deformation do you get by simply applying the vertical load I entered in a static analysis?
It is eight or nineth frequency. I used your file:
- double click on analysis
- double click on solver
- change analydis to frequency
- write input file
- change element type to B32R in input file (see work around)
- click on run ccx
- write input file
- click on run ccx
