FEM object types
Re: FEM object types
yes, and no referen shapes at the material.
Bernd, with your FreeCAD file I get the following error:
Then, when I replace the solver in your file ("CalculiXccxTools") with the experimental solver "SolverCalculiX" from the Solve > Solver CalculiX(experimental) menu, then I don't get the error, but only the S6 elements are written to file.
PS: the "CalculiX_static_results" from your FreeCAD file look very funny when I display them. This is before making any changes to your file
Could I have compiled the wrong branch?
yes, check help about in FreeCAD for the branch name you used for compiling, or inside source code in a bash put in git status and you will get the branch informations. I may post some git commands tommorrow which may help.
BTW: the experimental calculix solver does not complain for a simple reason, nothing is checked, thus he does not complain about any problem in an analysis.
I guess it's MASTER:
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13470 (Git)
Hash: 656a669cb0dc3d2d3becf20a5330531233b56834
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
What should it be if correct?
ahh the funny results is because of the problem in the other topic. If 3D beam or shell results are saved the result mesh is normalized. We need to find a fix for this. I may post the results without 3D result option activated.
yep seams my master which is same as FreeCAD master ...
git clone https://github.com/berndhahnebach/FreeCAD_bhb -b femmixedmeshes
cd FreeCAD_bhb
git status
or the smart way in your existing git repo
git add remote bernd https://github.com/berndhahnebach/FreeCAD_bhb
git fetch bernd
git checkout remote/bernd/femmixedmeshes
git status
Since I'm on the way I could not test them, so hopefully no typo.
Thanks Bernd !
I think you mean "git remote add ..." instead of "git add remote..."
Also: git checkout remote/bernd/... gives "did not match any files". However checkout bernd/... succeeds, but git status gives "head detached at" bernd/femmixedmeshes.
I will try to compile and see what happens
