Problem with nonpositive jacobian - help appreciated
HoWil
Postby HoWil » Sat Mar 04, 2017 9:23 am
Dear all,
I entcounter a problem regarding a eigenfrequency simulation with calculix in FC.
I have the following model and can run a static simulation but when switching to frequency-analysis I see the following error messages:
v1p04_crosssection_tmp2.fcstd
(320.91 KiB) Downloaded 65 times
Active analysis found: Analysis
We gone start GMSH FEM mesh run!
  Part to mesh: Name --> Extrude,  Label --> Extrude, ShapeType --> Solid
  CharacteristicLengthMax: 1e+22
  CharacteristicLengthMin: 0.0
  ElementOrder: 2
  ElementDimension: 3
  /tmp/Extrude_Geometry.brep
  /tmp/Extrude_Mesh_TmpGmsh.unv
  /tmp/shape2mesh.geo
  gmsh
  No mesh group objects.
  Group meshing.
  No mesh regions.
Start: ViewProviderFEMMeshBuilder::createMesh() =================================
    0.001000: Start build up 13940 face helper
    0.029000: Start eliminate internal faces SIMPLE
    1.199000: Start build up node map
    1.210000: Start set point vector
    1.213000: Start count triangle size
    NumTriangles:10776
    1.213000: Start build up triangle vector
    1.273000: Start build up edge vector
    NumEdges:16164
    1.281000: Finish =========================================================
  The Part should have a pretty new FEM mesh!
ThermalConductivity not found in material data of: None
ThermalExpansionCoefficient not found in material data of: None
SpecificHeat not found in material data of: None
FEM preferences working dir is not set, the solver working directory is used.
Dir '' doesn't exist and cannot be created.
Dir '/tmp' will be used instead.
FemTools.setup_working_dir()  -->  self.working_dir = /tmp
FemInputWriterCcx --> self.dir_name  -->  /tmp
FemInputWriterCcx --> self.main_file_name  -->  Extrude_Mesh.inp
FemInputWriterCcx --> self.file_name  -->  /tmp/Extrude_Mesh.inp
('  ReferenceShape : ', 'Face', ', ', 'Extrude', ', ', u'Extrude', ' --> ', 'Face1')
('  ReferenceShape : ', 'Face', ', ', 'Extrude', ', ', u'Extrude', ' --> ', 'Face2')
('  ReferenceShape : ', 'Face', ', ', 'Extrude', ', ', u'Extrude', ' --> ', 'Face3')
('  ReferenceShape : ', 'Face', ', ', 'Extrude', ', ', u'Extrude', ' --> ', 'Face4')
Writing time input file: 0.327914
Invalid Signal signature: textchanged()
Writing time input file: 0.452673
Analysis failed with exit code 201
--------start of stderr-------
--------end of stderr---------
--------start of stdout-------
CalculiX Version 2.9, Copyright(C) 1998-2015 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on Thu Jan 21 05:18:00 UTC 2016
  The numbers below are estimated upper bounds
  number of:
   nodes:         7532
   elements:         6543
   one-dimensional elements:            0
   two-dimensional elements:            0
   integration points per element:            4
   degrees of freedom per node:            3
   layers per element:            1
   distributed facial loads:            0
   distributed volumetric loads:            0
   concentrated loads:            0
   single point constraints:         3264
   multiple point constraints:            1
   terms in all multiple point constraints:            1
   tie constraints:            0
   dependent nodes tied by cyclic constraints:            0
   dependent nodes in pre-tension constraints:            0
   sets:            4
   terms in all sets:        23122
   materials:            1
   constants per material and temperature:            2
   temperature points per material:            1
   plastic data points per material:            0
   orientations:            0
   amplitudes:            1
   data points in all amplitudes:            1
   print requests:            2
   transformations:            0
   property cards:            0
 STEP            1
 Frequency analysis was selected
 Decascading the MPC's
 Determining the structure of the matrix:
 number of equations
 19332
 number of nonzero lower triangular matrix elements
 603945
 Using up to 4 cpu(s) for the stress calculation.
 *ERROR in e_c3d: nonpositive jacobian
        determinant in element        6195
        determinant in element        6196
        determinant in element        6205
--------end of stdout---------
CalculiX failed ccx finished with error 201
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _FemSolverCalculix
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _FemMeshGmsh
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _FemMaterial
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _FemMechanicalResult
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _ViewProviderFemSolverCalculix
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _ViewProviderFemMaterial
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _ViewProviderFemMeshGmsh
    0.000000: Start build up 2016 face helper
    0.004000: Start eliminate internal faces SIMPLE
    0.019000: Start build up node map
    0.020000: Start set point vector
    0.021000: Start count triangle size
    NumTriangles:1760
    0.021000: Start build up triangle vector
    0.026000: Start build up edge vector
    NumEdges:2640
    0.026000: Finish =========================================================
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _ViewProviderFemMechanicalResult
    NumTriangles:1760
    NumEdges:2640
First I thought the selected material (calculix-steel) is producing the problem due to missing density entries, but I built another model with simpler geometry and everything works fine.
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10412 (Git)
Build type: Unknown
Branch: femdev
Hash: 9229026ea3348cfa6eec93d1e7086359b5f6a508
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
also tried/rebuilt it on and a two days old master version, did rebuild it several times because FC-material did change a lot:
Version: 0.17.10168 (Git)
Build type: None
Hash: 6630bcf9fa8e849fe846d1c2b780148a7a2c1e4b
Here the simpler but working model:
fem_gmsh_test.fcstd
(732.66 KiB) Downloaded 54 times
I do not know why it is working with the simpler geometry and appreciate any hints and help.
Thanks in advance,
HoWil
joha2
Re: Problem with nonpositive jacobian - help appreciated
Postby joha2 » Sat Mar 04, 2017 11:11 am
First of all I would say the mesh is quite too coarse. Further some of the elements look quite distorted. I switched back to a first order mesh (i.e. tet4 elements) and it worked (but I think that is not useful for you).
Further I increased mesh resolution (0.1 mm) and it showed me that there are perturbations in the geometry to (i.e. places where the geometry is shown plane, but the mesh density increases.)
These perturbations are located where your wires (from a draft?) are broken. Maybe you should try to make the wires straight and afterwards extrude. Maybe this removes the element distortion and therefore the negative Jacobian determinant.
Hope this helps.
Best wishes
Johannes
HoWil
Postby HoWil » Sat Mar 04, 2017 12:23 pm
Hi Johannes,
thanks for your reply.
I used a coarse mesh to be able to upload the file. I thought that since the mesh can be created by gmsh and since it is imported into FC it can't be the problem. Maybe I was wrong.
I will look into it and report back.
BR,
HoWil
HoWil
Postby HoWil » Sat Mar 04, 2017 1:42 pm
joha2 wrote: These perturbations are located where your wires (from a draft?) are broken. Maybe you should try to make the wires straight and afterwards extrude. Maybe this removes the element distortion and therefore the negative Jacobian determinant.
If this is the problem ..... why is the mesh working for static simulations?
If this is the sollution (can't) check it because I am not familiar engough with draft-wb to fix/remove the short line causing the inhomogenious mesh.
BR,
HoWil
joha2
Postby joha2 » Sat Mar 04, 2017 2:46 pm
HoWil wrote:If this is the problem ..... why is the mesh working for static simulations?
Yeah and why is it working with 1st order elements? And it didn't work either with 2nd order mesh and the 0.1 mm resolution.
Therefore I would think, that not the coarse mesh is the problem. Unfortunately I am not sure how the tet10 element is treated.
Can it be badly deformed (inside out and things like that) by just meshing a hard geometry?
HoWil wrote:If this is the sollution (can't) check it because I am not familiar engough with draft-wb to fix/remove the short line causing the inhomogenious mesh.
I am also not familiar with it. How did you generate the original shapes?
Best wishes
Johannes
UR_
Postby UR_ » Sat Mar 04, 2017 7:30 pm
after cleaning shapes from ultrashort segments, everything works fine.
I have used WB Draft-> Draft to Sketch
- Deleting unwanted line segments
- Renew constrains
That's all
v1p04_crosssection_tmp.ur.fcstd
(358.65 KiB) Downloaded 35 times
HoWil
Postby HoWil » Sat Mar 04, 2017 8:43 pm
UR_ wrote:Hello,
- Renew constrains
That's all
Hello UR_,
Nice finding. I also learned hot to clean such 2D-drawings :D .
Thanks for your effort!
BR,
HoWil
bernd
Postby bernd » Mon Mar 06, 2017 8:04 pm
UR_ wrote:I have used WB Draft-> Draft to Sketch
- Renew constrains
Nice one :)
@HoWil: you can show the bad elements with cgx
start cgx with
$ cgx -c Extrude_Mesh.inp
Menue Viewing --> Show Bad Elements --> the bad ones will be green
bernd
Postby bernd » Mon Mar 06, 2017 8:24 pm
in FreeCAD ...
watch for output of ccx ...
obj = App.ActiveDocument.getObject("Extrude_Mesh")
nodes = list(obj.FemMesh.getElementNodes(6195))
Gui.ActiveDocument.Extrude_Mesh.HighlightedNodes = nodes
# Gui.ActiveDocument.Extrude_Mesh.HighlightedNodes = []
HoWil
Postby HoWil » Mon Mar 06, 2017 8:51 pm
bernd wrote: @HoWil: you can show the bad elements with cgx
Thx for pointing this out!
Any ideas to highlight the according elements as 'problematic' in FC? I just wonder how this could be circumvented for the next user facing such a problem since I thought i have a valid solid and a valid mesh.
EDIT: @Bernd I just saw your last plot where you highlighted the elements in FC.
BR
HoWil
