Calculix: *WARNING in usermpc: no MPC is generated for the mean rotation in node 736
UR_
Postby UR_ » Mon Mar 06, 2017 11:11 pm
in my current FEM-study a warning is generated by calculix.
"lochtraeger" shell elements, point load
lochtraeger.FCStd
(295.74 KiB) Downloaded 23 times
calculix console output (a little bit lengthy):
0.0: Check dependencies...
0.2: Write completed.
0.0: CalculiX binary: C:/Program Files/FreeCAD/bin/ccx.exe
0.0: Run CalculiX...
0.0: Starting CalculiX...
0.0: CalculiX is running...
5.7: CalculiX stopped.
5.7: ************************************************************
CalculiX version 2.8p2, Copyright(C) 1998-2015 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
Built for 64 bit Windows by Convergent Mechanical
For the latest version go to: bConverged.com
You are using an executable made on Fri May 1 09:38:01 PDT 2015
Decascading the MPC's
Determining the structure of the matrix:
number of equations
48983
number of nonzero lower triangular matrix elements
2098674
Using up to 1 cpu(s) for the stress calculation.
Factoring the system of equations using the symmetric spooles solver
Using up to 1 cpu(s) for spooles.
The numbers below are estimated upper bounds
number of:
nodes: 231116
elements: 4314
one-dimensional elements: 0
two-dimensional elements: 3498
integration points per element: 9
degrees of freedom per node: 3
layers per element: 1
distributed facial loads: 0
distributed volumetric loads: 0
concentrated loads: 8
single point constraints: 252264
multiple point constraints: 419761
terms in all multiple point constraints: 2686465
tie constraints: 0
dependent nodes tied by cyclic constraints: 0
dependent nodes in pre-tension constraints: 0
sets: 4
terms in all sets: 21501
materials: 1
constants per material and temperature: 2
temperature points per material: 1
plastic data points per material: 0
orientations: 0
amplitudes: 2
data points in all amplitudes: 2
print requests: 2
transformations: 0
property cards: 0
and direction 4
rotation in node 737
and direction 4
rotation in node 723
and direction 4
rotation in node 724
and direction 4
rotation in node 725
and direction 4
rotation in node 726
and direction 4
rotation in node 727
and direction 4
rotation in node 728
and direction 4
rotation in node 729
and direction 4
rotation in node 730
and direction 4
rotation in node 731
and direction 4
rotation in node 732
and direction 4
rotation in node 733
and direction 4
rotation in node 734
and direction 4
rotation in node 735
and direction 4
rotation in node 15
and direction 5
rotation in node 16
and direction 5
STEP 1
Static analysis was selected
Job finished
5.7: CalculiX done!
5.7: Loading result sets...
This is one of bespoken nodes, here node 736:
If max. elements size is set to 0 (automatic) gmsh shows a warning about mesh distortion
I have tried max. element sizes down to 3 mm with no result.
If this is a safety component, can i sleep in peace next days ;)
my used version:
Version: 0.17.10356 (Git)
Hash: cd1f010fe75ee672b0afe684c95736d850c01c93
Python version: 2.7.8
OCC version: 7.0.0
bernd
Re: Calculix: *WARNING in usermpc: no MPC is generated for the mean rotation in node 736
Postby bernd » Mon Mar 06, 2017 11:28 pm
Hi UR_
welcome to the world of FreeCAD FEM. You are new to the Forum, but for sure you does not seam to be new to FreeCAD ( https://forum.freecadweb.org/viewtopic. ... 75#p163194 ;) ) In the regard of your problem. You seam to use the ccx binary which is delivered with FreeCAD windows do you ? You use ccx binary 2.8p2, compiled Fri May 1 09:38:01 PDT 2015 . On my system I use 2.11 "You are using an executable made on So 31. Jul 13:26:31 CEST 2016" With your file I get no warning and no errors. The results seam fine for me too.
my output:
0.1: Write completed.
0.0: CalculiX binary: /usr/bin/ccx
1.3: CalculiX stopped.
1.3: ************************************************************
CalculiX Version 2.11, Copyright(C) 1998-2015 Guido Dhondt
number of:
nodes: 231116
elements: 4314
tie constraints: 0
sets: 4
materials: 1
orientations: 0
amplitudes: 2
print requests: 2
transformations: 0
property cards: 0
STEP 1
number of equations
48956
2095554
Using up to 2 cpu(s) for the stress calculation.
Using up to 2 cpu(s) for the symmetric stiffness/mass contributions.
Using up to 2 cpu(s) for spooles.
Job finished
1.3: CalculiX done!
1.3: Loading result sets...
you should get a newer ccx binary version for your system and FreeCAD should get it too :o
cheers bernd (gruss an den lochträger :mrgreen: )
bernd
Postby bernd » Mon Mar 06, 2017 11:42 pm
BTW: for the arrows in the fixed constraint there seams to be the same problems we discussed already ... https://forum.freecadweb.org/viewtopic.php?f=18&t=20562
