strange result for contact constraint
UR_
Postby UR_ » Tue Mar 14, 2017 9:58 pm
I am running into an strange issue, while doing some analysis containing contact constraints.
There was something wrong with provided results.
So i setup appended test case with known analytical solution
doppelbalken.FCStd
(790.52 KiB) Downloaded 21 times
Here deflection should be
[/quote]
I have tested two binaries for windows
cygwin build:
https://github.com/easyw/ccx_prool/blob ... _MT-64.exe
referenced here:
https://forum.freecadweb.org/viewtopic. ... 30#p137816
with this result
result easyw.png (22.55 KiB) Viewed 702 times
and this
mingw64 build:
https://github.com/ddfem/ccx_mingw64/bl ... .11_MT.exe
with this result
result ddf.png (20.87 KiB) Viewed 702 times
Have i done something wrong, or overseen? :?
Done with:
Version: 0.17.10460 (Git)
Hash: 91c59c7910436c44ede608e29d9a90a287121a11
Python version: 2.7.8
OCC version: 7.0.0
bernd
Re: strange result for contact constraint
Postby bernd » Tue Mar 14, 2017 10:39 pm
I have not yet tested your files. What I can tell is different ccx binaries could give different results, yes. I had similar issue. You may read this topic: https://forum.freecadweb.org/viewtopic.php?f=18&t=20276 The maintainer said some ccx uses patched libraries for compiling.
I'm gone try your example too.
