CalculiX 2.12 Available
http://www.dhondt.de/new_calc.htm
New features in Version 2.12 of CalculiX (check the documentation!)
Procedures
Specific gas network elements (such as GAS PIPE FANNO) can be used in a purely thermal calculation (parameter THERMAL NETWORK on the *STEP card); in combination with the user subroutine film.f the heat transfer coefficient is determined by use of the Glielinski equation (cf. example beamhtfcnu.inp).
Improved the convergence of gas networks.
Updated the calculation of sensitivities (cf. *SENSITIVITY)
Coded *GREEN function calculations (response to unit forces at certain locations of the structure)
accelerated the reading of the global model in *SUBMODEL calculations.
Coupling
Implemented the BEAM nonlinear MPC.
Coded *COUPLING followed by *KINEMATIC.
Coded *COUPLING followed by *DISTRIBUTING.
Elements
The GASPIPE network element was removed. Instead, the GASPIPE FANNO element should be used.
Coded the SPRING1 and SPRING2 element.
Coded the MASS element.
For shells a local coordinate system is automatically established by projecting the global or local (if defined by the user) x-axis on the shell surface.
Coded 6-node composite elements.
Documentation
Updated the theoretical description of gas network elements.
Output
Added the orientation in the dat-file for the quantities stored in local coordinates.
Coded *SECTION PRINT for the output of heat flux, section forces, section moments and section areas.
Included the relative stress error (heuristic relations) in the output of the error estimator ERR
Procedures
Coupling
Elements
Documentation
Output
Re: CalculiX 2.12 Available
Hi Michaelmakkemal wrote:http://www.dhondt.de/new_calc.htm
I have built a 64bit MT of the ccx 2.12 version for windows 64bit here
https://github.com/easyw/ccx_prool/tree ... lder/win64
win64/ccx2_12_MT-64.exe
would you mind to test it?
I've done some little testing and it seems fine to me
Thx in advance
Maurice
Hello,
this is result of test suite from here
http://www.dhondt.de/ccx_2.12.test.tar.bz2
done on
win 10 x64 14393.969
OMP_NUM_THREADS=1
Has anybody a result file for native (linux) build?
Divergences are a little bit frightening
Tomorrow i will do a test run on this build
https://github.com/ddfem/ccx_mingw64
done on
OMP_NUM_THREADS=1
Now tested this build:
https://github.com/ddfem/ccx_mingw64/bl ... 2_MTNO.exe
also done with:
OMP_NUM_THREADS=1
See some informations here:
http://mecway.com/forum/discussion/405/ccx-2-12
reducing compiler optimizations seems to work.
also done with:
OMP_NUM_THREADS=1
I added also 32b MT buildmakkemal wrote: Caluclix launcher also updated
https://yadi.sk/d/UB72nDqrtw3aZ
ccx2_12_MT-32.exe
Maurice
do you have an instruction (script) how to build calculix. I would like to create packages for conda.
are you using spooles and arpack?
Hi @looolooo wrote:do you have an instruction (script) how to build calculix. I would like to create packages for conda.
if you were meaning for windows, you can look at my repo which is a slight modified of the ccx_prool repo
there you can find a makeMT212.sh file to build it...
I'm using Cygwin64 with spooles and arpack
Thank, nice you have set up a repo for calculix. This will definitely help a lot.
linux is first, if this works I may try to build with windows. But I have no idea if there is a fortran compiler in visual studio that works for calculix.
Finaly *MASS is added
