For sure we should support any case. Someone could even try to import a vtk created with some totally different software.m42kus wrote: ↑Tue Jun 27, 2017 8:56 am Just looked at the source and notized that the variable names that are imported are hardcoded to "Displacement" and "Temperature". ElmerSolver names them "displacement" and 'temperature". I tried to change that but it seems like ElmerSolver ignores case... i already posted a question on elmer forum: http://www.elmerfem.org/forum/viewtopic ... b5fbdbea8e . However, would you (bernd or ickby) mind supporting both variants?
Edit: If it wasn't clear: After I changed them from "Displacement" and "Temperature" to "displacement" and "temperature" in the FreeCAD source the import worked
@markus:
Would it be possible for you to make the appropriate changes in FreeCAD source code ?
