You are right, I used a 3D-FC-model too. Its the same in the cfd-of-wb (openfoam), you must "construct"
the original 2D-case as 3D. I aborted the calculation after more than 1 hour runtime, it seems that the elmer-solver does not
converge on the 3D-calculation (the 2D-case converges after 5 min...). It would be helpful to see the residuals when running elmer
in FC like in the cfd-of-wb. However, I am not very familiar with elmer, maybe I did something wrong. On the other hand:
in the tutorial itself they talk about convergence problems...
I will use a "real world problem" (3D-flow around a cylinder) as I did in cfd-wb with openfoam.
it's a long long way to tipperary
For me the most interesting tutorial is nr. 9:
