Now there are nonpositive jacobian
Hallo,
i have a new problem.
The story behind.... some months ago I simulated a part with its eigenmodes. It worked perfect, but i do not remember the exact version of freecad.
Because of other projects I use always the newest daily build.
Now I have to simulate the old part again, no problem i thought. But it is ... there are now non positive jacobians !?! in the same file... whats going on .. spend 8 hours on it now I'm here.
gmsh wtihout errors or warnings.
cgx without bad elements
ccx nonpositive jacobians
Any ideas?
Thanks
Any ideas?
Thanks
Re: Now there are nonpositive jacobian
your file runs fine for me on ccx 2.11
But I had some problems to on simple shapes too with frequency. See https://forum.freecadweb.org/viewtopic.php?f=18&t=22673 Try a static analyais by fixing some face and applying a force or a pressure. Does it helps.
bernd
bernd
There is another one you could try. Use the netgen mesher. It produces better tetra meshes than gmsh, ccx has less problems with.
Hallo bernd,
do you have changed anything on the mash, that was in the file, or did you only start a new simulation?
Yes, that is the result I had before, now it doesn't work any more... I tried different versions of ccx. 32 bit - 64 bit MT an non MT.
The fact is, that it works a few weeks ago. But not at the moment.
I testet it on 2 different machines, later on Linux.
Now I think the problem is in front of the Screen
I will check it again.. and will check out, how to use the netgen mesher
Thanks a lot for this moment.
download your file, start FC, load your file, activate the analysis, select the solver, press the run button.
BTW: you are not the first one spending hours on non-positive jacobians. I implemented some highliting. If you use the run button the non-positve should be green. See screen here: https://forum.freecadweb.org/download/file.php?id=38080 Does this word for you. Do you get lots of them?
Mostly it helps to make a finer mesh or add some loads an a fixed face and have a look if a static analysis works.
Bernd
Bernd
I can reproduce the problem. It helped when I changed position of the mesh in property editor to move out of axes (to have mesh without nodes with some coordinate being 0). It also helped when I changed positions coordinates like
to
From this perspective, it looks like problem is in the formatting of very low numbers in the inp file.
OS: Windows 7
Version: 0.17.11203 (Git)
Hash: e2e1f44b45737f8b900a4ac7766f8f064c434638
Python version: 2.7.8
OCC version: 7.1.0
*Node, NSET=Nall
130, 85.06, -14.75, -3.09452848545541e-014
*Node, NSET=Nall
130, 85.06, -14.75, 0
OS: Windows 7
OCC version: 7.1.0
Hello fandaL,fandaL wrote: ↑Thu Jun 01, 2017 10:12 pmCode: Select all
*Node, NSET=Nall ... 130, 85.06, -14.75, -3.09452848545541e-014
"-3.09452848545541e-014" is an illegal floating point format
ccx reads only F20.0 (i. e. Fortran floating point field 20 chars wide)
pending chars are not accepted, that means -3.09452848545541e-014 becomes -3.09452848545541e-0
That should be avoided.
BTW, i got these jacobians all day long and spend a lot of time figuring out whats going on.
But i never counted chars
Does it mean we changed the prececision to a to much hight value here: https://github.com/FreeCAD/FreeCAD/blob ... .cpp#L1191 done git commit e58b7479
Hey all,
thanks a lot for your fast support!
This workaround works fine for me!
Peter
Peter
Hello bernd,
there is a overhead in iostream caused by signs, decimal separator and exponents.
please have a look at this example
// floatfield
#include <iostream> // std::cout, std::defaultfloat
int main () {
double a = .1234567890123456789;
double b = -.1234567890123456789;
double c = 100000000000000000000.;
double d = -100000000000000000000.;
double e = -0.1234567890123456789e-101;
double f = +0.1234567890123456789e+101;
std::cout.precision(13);
std::cout << "defaultfloat:\n" << std::defaultfloat;
std::cout << "12345678901234567890\n";
std::cout << a << '\n' << b << '\n' << c << '\n' << d << '\n' << e << '\n' << f << '\n';
return 0;
defaultfloat:
0.1234567890123
-0.1234567890123
1e+020
-1e+020
-1.234567890123e-102
1.234567890123e+100
