Compatibility for mesh and postprocessing in all FEM related wbs
Moderator: oliveroxtoby
HoWil
Post by HoWil »
Today I tested the CFDFoam-wb the first time and I really liked playing with it. I saw new, enhanced dialogs for selecting boundary conditions and tested new mesher like cfMesh.... pretty cool new stuff for me.
So I tried to use the mesh created in CFDFoam with a calculix analysis in FEM-wb. First I used a gmsh-object mesh in CFDFoam and copy pasted it to reuse the copy with calculix. After my first success running an analysis I tried the same with cfMesh-object. I also copy-pasted the mesh which creates also a copy of the original geometry and set up the simulation as in the gmsh case. When I now run the simulation I get
'Missing prerequisit(s); FEM mesh has no volume elements, either define a shell thickness or provide a FEM mesh with volume elements'
I think this is only a small thing and hopefully can be "solved" easily.
What I ask for here is keeping elements for meshing (pre-) and postprocessing FC-wide as standardized, reusable or compatible as possible. From the perspective of a user I would love to reuse a mesh created for openfoam for an analysis in calculix or even Elmer. The same is for sure valid for dialogs. I also write this with some self-interest.... I am one of the mentors for the Elmer-integration and do not want to have our student to reinvent everything :D .
What do you think ... is this possible or are the different workbenches already fragmented to much.
BR,
HoWil
Re: Compatibility for mesh and postprocessing in all FEM related wbs
Post by bernd »
Would you post an example FreeCAD file with such cfMesh ? Are your really sure it has volume elements. The foam guys work quite a lot with shell meshes.
It should make no difference where the mesh comes from, either manuall by python, by gmsh, by netgen or by any of the import filter or even this cfMesh. Internally they are all saved in the FreeCAD smesh structure, means SMESH does not even know where the mesh comes from.
Ahh for sure +1 no matter where the mesh comes from it should be usable with any other solver too !
HoWil
Post by HoWil »
bernd wrote: Thu Jun 15, 2017 7:37 pm Would you post an example FreeCAD file with such cfMesh ?
Did add a CFDFoam analysis next to a calculix-gmsh one. Hope you can open it without CFDFoam-wb.
FemCalculixCantilever3D_cfMesh.fcstd
(108.96 KiB) Downloaded 106 times
Screenshot from 2017-06-17 22-04-19.png (308.96 KiB) Viewed 2435 times
And the same with snappyhexmesh:
FemCalculixCantilever3D_snappy_hex_mesh.fcstd
(85.87 KiB) Downloaded 91 times
Screenshot from 2017-06-17 22-09-42.png (308.88 KiB) Viewed 2435 times
BR,
HoWil
Post by bernd »
as assumed, the meshes are face meshes only. Open one of your documents, activate FEM workbench, select the mesh right mouse click print mesh info. -> no volumes ... see screen. Means only the surface of the cantilever is meshed. What you could do is add a shell thickness of may be 50 mm and you have a hollow section profile ... and get results for this hollow section profile ... see scree attached ...
HoWil
Post by HoWil »
I see.... you are completely right. But this makes no sense the CFDFoam guys also need volume-meshes!?
oliveroxtoby wrote:A short question
Is this the correct behaviour of cfmesh? Shouldn't it produce volume meshes? Did I install it in a wrong way?
EDIT: cfmesh should work I remeshed the elbow example and it could be solved (3D flow results of a 3d mesh model)!
Here a look at the related mesh data of the solved cfmesh elbow-example listing 0 Volume elements:
Screenshot from 2017-06-19 20-21-22.png (274.67 KiB) Viewed 2391 times
Is only the mesh info wrong for cfmesh and snappyhexmesh?
BR
HoWil
oliveroxtoby
Post by oliveroxtoby »
HoWil wrote: Mon Jun 19, 2017 6:25 pm I see.... you are completely right. But this makes no sense the CFDFoam guys also need volume-meshes!?
BR
HoWil
Sorry for the bad news, but unfortunately the mesh displayed in FreeCAD is only the outer shell of the full mesh. As cfMesh and snappyHexMesh write their results in OpenFOAM format, there is no functional need for us to read the full mesh into FreeCAD, and so the boundary mesh displayed is purely for visualisation. Someone would need to write an importer to read from the OpenFOAM format...
