Displacement rotation not applied
Using the displacement constraint I try to apply a torque on a femmesh but for some reason it is not included in the calculation.
I tried different rotation axis/ angels and played with the free/fixed setting but nothing changed.
Also when I type a rotation in the task view of the displacement both free and fixed are set to false.
If I use the property view I can set these parameters.
- selfmadeAFO.FCStd
- (301.02 KiB) Downloaded 66 times
Re: Displacement rotation not applied
I apply the rotation on the geometry, it is visualised in the editor.
But I get an error:
Invalid Signal signature: textchanged()
Base.FreeCADError: PyArg_ParseTuple failed. Invalid arguments used with setNodeByScalars
Thank you for the solutions, but they don't really help me.
I said torque, but my semantics are wrong, I want to do a displacement not apply a force
When I open your model and run it I get the following... is this what you want/expect?:
https://forum.freecadweb.org/viewtopic. ... 212#p98139 .
BR,
HoWil
OS: Ubuntu 16.04.3 LTS
Version: 0.17.11740 (Git)/Daily-PPA
Build type: None
Hash: 6b05302c2e70f191a2a5787f55c5b549155b9824
Python version: 2.7.12
OCC version: 7.1.0
Are these settings for the Rotation in x, y, z correct/intended?
Which version of FC do you use? Please see BR,
HoWil
Build type: None
OCC version: 7.1.0
Yes, that's the same result as me.
But, that is not the result I wanted.
I'm trying to rotate the selected face in the displacement constraint.
Now it is only displaced by translation.
Well, for now, any setting that would have a rotation in the resulting analysis is ok.
These settings is me trying different combinations of values.
OS: Windows 10HoWil wrote: ↑Tue Aug 08, 2017 2:42 pm Which version of FC do you use? Please see https://forum.freecadweb.org/viewtopic. ... 212#p98139 .
Version: 0.17.11508 (Git)
Hash: 087a1c1056d56e7bef0ce3bc6e367441fa0e3a9f
Python version: 2.7.8
OCC version: 7.1.0
Nop not really.
I just wanted to help to understand the question correctly.
I think the main point regarding your question is that the dialog box states "Rotations are only valid for Beam and Shell elements". So, I think it does not work for "real" 3d problems.
BR
Howil
BR
Howil
If you need a rotational MPC, you will need some special approach.
* First joice is a bond to a rigid body. But this is at the moment not available, so we need a feature request in this regard.
* Second choice is you needs to imitate rigid body by a dummy.
This dummy need a significant higher young modulus and a cylindrical face.
A translational displacement needs to be defined first, which is transformed to a cylindrical coordinate system in a pending step.
So X-axis will be translated to radial displacement,
Y-axis will be translated to tangential displacement and Z-axis remains as cylinder's axis.
This will lead to this result:
File:
Done with:OS: Windows 10
Version: 0.17.11792 (Git)
Hash: 7aec98ffb66065854a66d6d6715845fdbf0869a7
OCC version: 7.1.0
File:
OCC version: 7.1.0
Hi bernd,bernd wrote:ping
if this https://forum.freecadweb.org/viewtopic. ... 50#p178208
will be released, is it possible to buildup a shell from a circle and bond it onto this cube's topface for constraining directly with a rotational FemDisplacement?
