Displacement rotation not applied
bernd
Re: Displacement rotation not applied
Postby bernd » Sat Aug 26, 2017 11:06 am
UR_ wrote:
Mon Aug 21, 2017 7:40 pm
bernd wrote:ping
Hi bernd,
if this https://forum.freecadweb.org/viewtopic. ... 50#p178208
will be released, is it possible to buildup a shell from a circle and bond it onto this cube's topface for constraining directly with a rotational FemDisplacement? :?:
We could give it a try, together. Since all constraints are applied on the geometry (FreeCAD FEM is so coooool :mrgreen: ) you could make the file like you described and I would give it a try to calculate it with my development branch.
You should get hands on a compiler and compile this branch yourself. Would be a good test for this mixed mesh branch before PR. :mrgreen:
BTW: all ccx, and mesh work is done. What is missing is the mesh view provider. I did hack the viewprovider to be able to display edges, faces from edges, faces and volumes at once. This needs to done in a smarter way before we can merge. Hopefully before 0.17 release.
