Materials dialogue problem
lambda
Re: Materials dialogue problem
Postby lambda » Mon Oct 16, 2017 7:32 pm
I haven't had time to test you changes yet. However some remarks from just looking at code that I mostly don't understand:
1. I think the code you propose is just a complicated version of saying
        if 'Density' in matmap:
            density = FreeCAD.Units.Quantity(matmap['Density'])
            self.form.input_fd_density.setText(density.UserString)
2. I guess this could fix a locale issue if there is one or any other issue with formating - I'm not fluent in python enough to predict what the old code actually did without trying. However given our conversation above it is unclear to me, what the issues actually are.
3. The wiki suggests that the dialog should use https://www.freecadweb.org/wiki/InputField instead of a text field. Maybe that option should be explored also.
HTH,
Harald
HoWil
Postby HoWil » Tue Oct 17, 2017 7:17 pm
bernd wrote: Ping
Could you please test this. Its really important for me.
@Harald: Yes, it is for sure not implemented optimally. I am a skript kiddy just copy pasting stuff I find somewhere :D . But it works :!:
@Bernd: Do you know a bit more about the mentioned InputFields (instead of text-fields)? I thought all fields with units are InputFields?
BR,
HoWil
lambda
Postby lambda » Wed Oct 18, 2017 5:35 pm
I will do, but I'm on a tight schedule at the moment and have a hard time fitting FLOSS work into the breaks between my job. However it would help a lot, if you could describe which tests you did already yourself and what the results have been.
Harald
HoWil
Postby HoWil » Wed Oct 18, 2017 6:08 pm
I will do
THX a lot :!:
8-) as everywhere. :o
Simply open the Fluild material dialogue with Air as depicted in my first post. Close it and reopen it again. Now check if the values have changed.
Look for changes like:
-Values grow each time you reopen ... 1.2 becomes 12 and 120
-Values are reset 0.02 becomes 0 or 1000
-Values are lost 0.054 becomes 0.05
BR
HoWil
bernd
Postby bernd » Wed Oct 18, 2017 6:10 pm
@HoWil:
as soon as the unit test for elmer is finished I will have a look at this here too.
lambda
Postby lambda » Wed Oct 18, 2017 9:05 pm
Actually, it is particularly bad for me at the moment.
The point would have been for you to tell us what you see (and in which locale) so that we can compare. Not to tell us where to look.
Anyway still hadn't time to test your changes, but got around to dissect the code a bit in the python console. Insights:
1. "{} {}".format(...) returns a standard string object, while Quantity.UserString returns an unicode string object. This might behave differently with respect to locales. However u"{} {}".format(...) (mind that 'u'!) also returns an unicode string object without any other changes in behaviour. So that would be the cleaner fix if this is actually the problem.
2. greping "{} {}".format(...) shows that the lines which you change are the only times where this construct is used in the entire code of FreeCAD. Looks quite fishy to me.
3. However, using Quantity.UserString as I suggested doesn't seem to work either. Actually, it seems that Quantity.UserString is where precision gets lost. See the transscript below.
4. I have the gut feeling that the code as is, is intended to work around the problem of Quantity.UserString, but accidentally dropped unicode support (no greek symbols anymore) and maybe has some sideeffects wrt locales. Your fix restores unicode support, but totally neutralized the workaround, because Quantity.UserString again is responsible for formatting. I hope that the proper Quantity-aware input widget from the wiki is solving this, but I don't know anything about this yet. - If you want a quick fix, I suggest to try prefixing the format string with 'u' as I have shown above.
Here is the transscript of my test session:
>>> sh = FreeCAD.Units.Quantity(App.ActiveDocument.FluidMaterial.Material['SpecificHeat'])
>>> sh
1.005e+06 mm^2/(s^2*K)
>>> shnu = "J/kg/K"
>>> shwnu = sh.getValueAs(shnu)
>>> shwnu
1.005
>>> "{} {}".format(shwnu, shnu)
'1.005  J/kg/K'
>>> sh.UserString
u'1.00 J/kg/K'
>>> sh.getUserPreferred()
(u'1.00 J/kg/K', 1000000.0, u'J/kg/K')
>>> q = FreeCAD.Units.Quantity("{} {}".format(shwnu, shnu))
>>> q
>>> q.UserString
u'1.00 J/kg/K'
>>> u"{} {}".format(shwnu, shnu)
u'1.005  J/kg/K'
bernd
Postby bernd » Thu Oct 19, 2017 6:16 pm
@HoWil:
Does your commit fixes one of the problems described here? https://github.com/berndhahnebach/FreeC ... t/c8262347
HoWil
Postby HoWil » Mon Oct 23, 2017 6:59 pm
@HoWil:
Yes, the above linked commit does solve the units problem in the material dialog (discussed/described in this post here) for me.
If nobody else does experience new problems, then it should be fixed.
BR
Howil
bernd
Postby bernd » Mon Oct 23, 2017 9:23 pm
Cool, have you read my pm in the regard of commiter mail?
HoWil
Postby HoWil » Wed Oct 25, 2017 11:09 am
Yes, will change that this evening or tomorrow.
BR
Wilfried
