beam analysis with beams in z-direction
Re: beam analysis with beams in z-direction
I am able to clone your repo https://github.com/berndhahnebach/FreeCAD_bhb but I can't seem to branch it.
I initially branched from FreeCAD master and it worked but then I tried to branch from Bernd and I was not able too. However I cloned it to my pc with the Kraken (really like this name!!!). So today I will finally check out the code. Since you changed the GUI I need this time to compile freeCAD. Am I correct?
After cloning with Kraken I can now branch it! Great program Thanks Kunda1!
My compile process failed. I would like to try and compile on another machine but it has windows. I found it difficult and confusing to setup compiling in windows 10. (Followed the FreeCAD compiling guide)
Is there some kind of homebrew for windows? In my mac machine with compile -j5 option still takes a while.
you could try to use conda. I have finally set-up a development environment of FreeCAD with qt5, py3 in kdevelop on windows10. There are some hacks necessary, (especially running kdevelop in a environment) which are not quite obvious, but I could guide you through that process.FemUser wrote:Is there some kind of homebrew for windows?
That is good enough for me! I will start installing Conda.
Installed. I am assuming that it will work with windows 7 same way.
@looo an aside, would you be able to write a tutorial for other devs on how to do this with conda ?looo wrote: ↑Thu Oct 26, 2017 7:13 amyou could try to use conda. I have finally set-up a development environment of FreeCAD with qt5, py3 in kdevelop on windows10. There are some hacks necessary, (especially running kdevelop in a environment) which are not quite obvious, but I could guide you through that process.FemUser wrote:Is there some kind of homebrew for windows?
@looo thanks... @Bernd I compiled the source but it seems to crash on my machine... The "standard" version runs well but changed source code doesn't.
just checked the development environment on windows again. There is still a problem with selecting the right python-interpreter:
https://forum.freecadweb.org/viewtopic.php?f=10&t=24718
