beam analysis with beams in z-direction
UR_
Re: beam analysis with beams in z-direction
Postby UR_ » Sat Oct 14, 2017 3:20 pm
Here we have a nice circle shaped beam.
So we have only one shape accessible for "Beam Section Parameter" input box to assign a cross section.
Screenshot CircleBeam-13mm charac Lmin.png (20.65 KiB) Viewed 688 times
Every is fine, because there is no element properly aligned to z axis.
Now we change "characteristic length min" to 12 mm and we get a single beam element aligned to z axis.
But we have no chance to assign another cross section and therefore we get an error message from ccx.
Screenshot CircleBeam-12mm charac Lmin.png (10.95 KiB) Viewed 688 times
FemUser
Postby FemUser » Sat Oct 14, 2017 3:30 pm
The bug gets fixed with the python script and looking at the image it is rotating 45º consistently. The good part of the script is that we can control rotation of the beam.
ni(-(a2+a3)/a1),1,1)
The two 1's control rotation about the two perpendicular axis. if 0,1 or 1,0 we get alignment to each normal axis. We could graphically control the normals this way with no problem, coordinate wise however I don't know much about how to actually modify the GUI but Bernd certainly knows.
FemUser
Postby FemUser » Sat Oct 14, 2017 3:31 pm
UR_ When I wrote the previous post I didn't see your post.
thschrader
Postby thschrader » Sun Oct 15, 2017 10:21 am
fandaL wrote:
Sat Oct 14, 2017 7:36 am
imho: If you rotate rectangular cross section you get globally different quadratic moments so that (on detailed level) it is different model and that's why I think that orientations of beams are quite important and "responsible" user :geek: should take care about them.
In the future It would be cool to display cross sections in the model with orientations and offsets.
Definition of beam axis/orientation in my comercial 3D-program. Taken from (text in german):
http://www.pcae.de/main/download/handbu ... ndbuch.pdf
For easy checking beam orientation there is a rendering module in the program.
FemUser
Postby FemUser » Sun Oct 15, 2017 11:03 am
Nice... thschrader I was wondering how things should look like but now it is clear. We aren't that far. And picking your figure makes clear we need to add another variable to the Beasec_obj -> my suggestion is add Section_nor which will hold the axis (n1,n2) see my previous post to know what is n1 and n2.
When we in the GUI have one elementgeometry1D icon this is generated:
** Element sets for materials and FEM element type (solid, shell, beam, fluid)
** written by write_element_sets_material_and_femelement_type function
*ELSET,ELSET=Mat0Beam0
Eedges
** Sections
** written by write_femelementsets function
*BEAM SECTION, ELSET=Mat0Beam0, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
When we in the GUI have one elementgeometry1D icon and another icon with a defined edge inside this is generated:
1,
2,
3,
4,
5,
6,
7,
8,
9,
10,
11,
*ELSET,ELSET=Mat0Beam1
12,
** Sections
2 , 1
*BEAM SECTION, ELSET=Mat0Beam1, MATERIAL=SolidMaterial, SECTION=RECT
25 , 10
I can't seem to figure out how to instead of Eedges to write the full list like is done for the multiple case, when we generate each beam we calculate its normal. When we make a individual beam these are separated from the general list and we can specify for that case only its normal. So it looks we can make the beam engine work as requested.
Now on the programming I am lost as one can be :) still figuring out how the program works.
I think these are important but am a bit lost...
get_ccx_elsets_single_mat_single_beam(self)
get_ccx_elsets_single_mat_multiple_beam(self)
Also I can't find the main object definition
beamsec_obj where the beam attributes should be.
FemUser
Postby FemUser » Sun Oct 15, 2017 2:30 pm
My first set objective is to create all normals from the default case (the case where we don't wish to define everything). If we want to control individually each beam axis we need to individually create a beam element and maybe there we can specify the normal for each set.
For the default case I think I need to change the behaviour to not create the "Eedges" field.
def get_ccx_elsets_multiple_mat_single_beam(self):
        beamsec_obj = self.beamsection_objects[0]['Object']
        for mat_data in self.material_objects:
            mat_obj = mat_data['Object']
            ccx_elset = {}
            ccx_elset['beamsection_obj'] = beamsec_obj
            ccx_elset['ccx_elset'] = mat_data['FEMElements']
            ccx_elset['ccx_elset_name'] = get_ccx_elset_beam_name(mat_obj.Name, beamsec_obj.Name, mat_data['ShortName'])
            ccx_elset['mat_obj_name'] = mat_obj.Name
            ccx_elset['ccx_mat_name'] = mat_obj.Material['Name']
            self.ccx_elsets.append(ccx_elset)
But I don't seem to see the Eedges field.
I noticed that the multi case is different:
    def get_ccx_elsets_multiple_mat_multiple_beam(self):
        for beamsec_data in self.beamsection_objects:
            beamsec_obj = beamsec_data['Object']
                ccx_elset = {}
                elemids = []
                for elemid in beamsec_data['FEMElements']:
                    if elemid in mat_data['FEMElements']:
                        elemids.append(elemid)
                ccx_elset['ccx_elset'] = elemids
                ccx_elset['ccx_elset_name'] = get_ccx_elset_beam_name(mat_obj.Name, beamsec_obj.Name, mat_data['ShortName'], beamsec_data['ShortName'])
FemUser
Postby FemUser » Sun Oct 15, 2017 3:17 pm
The final result I am looking for is the following:
1,
2,
*ELSET,ELSET=Mat0Beam2
3,
*ELSET,ELSET=Mat0Beam3
4,
*ELSET,ELSET=Mat0Beam4
5,
*ELSET,ELSET=Mat0Beam5
6,
*ELSET,ELSET=Mat0Beam6
7,
*ELSET,ELSET=Mat0Beam7
8,
*ELSET,ELSET=Mat0Beam8
9,
*ELSET,ELSET=Mat0Beam9
10,
*ELSET,ELSET=Mat0Beam10
11,
*ELSET,ELSET=Mat0Beam11
12,
** Sections
2 , 1
0,n11,n12
2 , 1
0,n21,n22
*BEAM SECTION, ELSET=Mat0Beam2, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n31,n32
*BEAM SECTION, ELSET=Mat0Beam3, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n41,n42
*BEAM SECTION, ELSET=Mat0Beam4, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n51,n52
*BEAM SECTION, ELSET=Mat0Beam5, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n61,n62
*BEAM SECTION, ELSET=Mat0Beam6, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n71,n72
*BEAM SECTION, ELSET=Mat0Beam7, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n81,n82
*BEAM SECTION, ELSET=Mat0Beam8, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n91,n92
*BEAM SECTION, ELSET=Mat0Beam9, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n101,n102
*BEAM SECTION, ELSET=Mat0Beam10, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n111,n112
*BEAM SECTION, ELSET=Mat0Beam11, MATERIAL=SolidMaterial, SECTION=RECT
2 , 1
0,n121,n122
the normal vector changes as calculated from 0,n1,n2 to n1,0,n2 to n1,n2,0 depending on the orientation of the bar this will be calculated.
n1....n121 is replaced by calculated values.
FemUser
Postby FemUser » Mon Oct 16, 2017 10:24 am
I am having a hard time debugging. I noticed that there is a FEM folder with .py and .pyc files that make the fem module, however when I attempt to change them nothing happens. I took all py files placed into a folder and still could generate a inp file in calculix menu. So how can see the change effects when I change the py file? Do I have to compile the whole program? I think not but I must be doing something wrong.
FemUser
Postby FemUser » Mon Oct 16, 2017 5:18 pm
I learned that I have to quit FreeCAD and come back in for it to read the changed python file. I know this is a newbee thing! :) I took me a while to understand this. I wish there was a less painful way to test the code...
FemUser
Postby FemUser » Mon Oct 16, 2017 6:39 pm
A bit hammered but the following code in the case we have only one beam element type
   def get_ccx_elsets_single_mat_single_beam_edit(self):
	beam_elm_count= len(self.beamsection_objects[0]['FEMElements'])
	for i in range (0, beam_elm_count):
        	mat_obj = self.material_objects[0]['Object']
        	ccx_elset = {}
		ccx_elset['ccx_elset'] = [self.beamsection_objects[0]['FEMElements'][i]]
        	ccx_elset['ccx_elset_name'] = get_ccx_elset_beam_name(mat_obj.Name, beamsec_obj.Name)
This will produce on the cube test subject the following:
1,
2,
3,
4,
5,
6,
7,
8,
9,
10,
11,
12,
