Abaqus writer, write group data
bernd
Postby bernd » Thu Nov 23, 2017 5:34 am
Lately I did extend the Abaqus writer. It is possible to write mesh groups to inp file. Once the PR is in master https://github.com/FreeCAD/FreeCAD/pull/1111 it works as follows ...
by Python:
# reads the params from import/export preference GUI
App.ActiveDocument.FEMMeshGmsh.FemMesh.write('/home/hugo/Desktop/groups/femmeshgroups2esets2.inp')
# uses the prefs passed with the method
App.ActiveDocument.FEMMeshGmsh.FemMesh.writeABAQUS('/home/hugo/Desktop/groups/femmeshgroups2esets2.inp', 0, True)
''' while
elemParam:
0 = all elements
1 = highest elements only
2 = FEM elements only (only edges not belonging to faces and faces not belonging to volumes)
groupParam:
true = write group data
false = do not write group data
On Gui just make your import/export prefs and export a mesh to inp.
example file attached ...
femmeshgroups2inpsets.fcstd
(20.02 KiB) Downloaded 18 times
HarryvL
Re: Abaqus writer, write group data
Postby HarryvL » Sat Mar 10, 2018 6:05 pm
Hi Bernd, this is a great feature. I plan to use it in CGX to review stress results in (hidden) Mesh regions of interest. Would it be possible to also export all group data to the CCX INP at the point of clicking "Write .inp file" before starting a CalculiX analysis? That saves me manually merging CCX input files. Thanks, Harry
HarryvL
Postby HarryvL » Sun Mar 11, 2018 4:31 am
Sorry Bernd, I think this is not as easy as I imagined. After trying *NODE FILE, NSET=Nset_name and *EL FILE, NSET=Nset_name (where Nset_name is a node set exported by FreeCAD) I found that you can only toggle a region in the CGX pre-processor (plot n Nset_name) and not the post-processor. Results are only shown for NSET, but the mesh for all other nodes stays visible (see below). Things become even more complicated when CCX introduces new nodes (OUTPUT=3D).
So from a CGX point of view there is not much justification for writing mesh regions to INP
Harry
fandaL
Postby fandaL » Sun Mar 11, 2018 8:55 am
open frd file in cgx
read inp file sets from input file by
read job_name.inp nom
display nsets and elsets by
prnt se
plot desired elset by e.g.
plot e SolidMaterialSolid
use gui to plot stresses or so
You can farther look at cgx manual or to examples at https://github.com/mkraska/CalculiX-Examples
HarryvL
Postby HarryvL » Sun Mar 11, 2018 9:13 am
Thanks fandaL, exactly what I needed :D
bernd
Postby bernd » Sun Mar 11, 2018 10:13 am
HarryvL this should not be to difficault to add as a pref. I will have a look when I have a minute.
bernd
bernd
Postby bernd » Sun Mar 11, 2018 12:43 pm
you can change this easily yourself for any analysis CalculiX inputfile writing by replaceing the False by a True in the file Mod/Fem/femsolver/calculix/writer.py in your Mod folder of FreeCAD.
https://github.com/FreeCAD/FreeCAD/blob ... ter.py#L81
to find the Mod folder you can put in this in your FreeCAD python console:
FreeCAD.ConfigGet("UserAppData")
Bernd
HarryvL
Postby HarryvL » Sun Mar 11, 2018 1:52 pm
Great, thanks :)
