Force displacement meaning
Vladi
Postby Vladi » Tue Feb 20, 2018 7:48 pm
Hello FreeCAD forum!
I'm trying to test a part. I use 0.16:
OS: Windows 7
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
First i add some force, for exaple 100 Newton:
link.
But I really dont understand, what does it mean in result screen:
Displacement: factor 1-100
It is my first force in 100 times, or the full force 100 percent?
So:
a: 100*100=10000
b: 100*1=100
Thanks. :D
thschrader
Re: Force displacement meaning
Postby thschrader » Wed Feb 21, 2018 2:25 pm
Hi Vladi,
the slider is for adjusting the deflection to check if the deformation is plausible
(if not, try an other model...)
The values are the max values calculated. In my example:
Beam steel 100x10x10 mm, 500 N loading. The theoretical z-deflection according
to beam-theory is 0,95 mm (in opposite z-dir). Thats what we got...
BTW: you should use FC0.17 for FEM:
https://forum.freecadweb.org/viewtopic.php?f=18&t=12212
Vladi
Postby Vladi » Mon Feb 26, 2018 6:56 pm
Thanks thschrader!
I will do again with 0.17 and come with results later!
