Stress Result in Shells
bernd
Re: Stress Result in Shells
Post by bernd »
with 1D elements the example is even simpler ...
shell-stress-result-problem-simplified2.fcstd
(17.47 KiB) Downloaded 26 times
FEMMeshGmsh.frd.txt
(4.95 KiB) Downloaded 28 times
Result_mesh001.frd.txt
(4.95 KiB) Downloaded 26 times
bernd
Post by bernd »
my problem is I'm not that good in C++ . I'm only familar with the Python FEM code since 95 % has been changed by myself. I'm still learning C++ I have been done lot's of stuff in this regard for FEM too, but it is not as easy as Python. Main problem in C++ is, it takes a lot of time and FreeCAD is just fun in my spare time ATM.
bernd
UR_
Funny observation
Post by UR_ »
Because faulty result mesh display has something to do with node numbering, i've started some test with a 2-element mesh (2 triangles shell mesh).
I tried to repair frd-file manually and found following:
Jumps and gaps in node sequence are without effect, as long as first node has number 1
Therefore a repair of 2d-example from FreeCAD's startpage is pretty easy.
known faulty display.
with repaired frd file
change all appearances from node "178" to "1" (6 times)
MAT    1SOLIDMATERIAL
    2C                           408                                     1
 -1         1 0.00000E+00 1.00000E+03 0.00000E+00
 -1       179 0.00000E+00 5.00000E+02 0.00000E+00
 -1       180 0.00000E+00 0.00000E+00 0.00000E+00
 -1       181 0.00000E+00 1.00000E+03 1.00000E+03
file:
FEMMeshGmshStart1.frd.zip
(22.61 KiB) Downloaded 20 times
HarryvL
Post by HarryvL »
Fantastic ... that's easily fixed :D
bernd
Post by bernd »
workaround with idea of _UR: https://github.com/berndhahnebach/FreeC ... ell2D3Dfix
but it is more a hack than a workaround. I'd like to fix the C++ ...
BTW: in any result section the node number is wrong than, I wonder how it worked for you anyway? NodeNumbers in result object should be wrong if you only change node numbers and element numbers in frd file.
UR_
Post by UR_ »
bernd wrote: Wed Feb 28, 2018 5:18 pm but it is more a hack than a workaround. I'd like to fix the C++ ...
Of course this observation isn't a blueprint for a workaround, source base shouldn't polluted that way.
It's mentioned for further debugging. ;)
I tried to understand under which circumstances these errors occur.
So i introduced gaps and backjumps to frd's node numbering and couldn't confuse viewprovider.
Only renaming node 1 is able to do.
bernd
Post by bernd »
first version of a fix. It works for me ...
https://github.com/berndhahnebach/FreeC ... diff=split
but I need to test this a bit more ...
bernd
Post by bernd »
UR_ wrote: Wed Feb 28, 2018 8:35 pm It's mentioned for further debugging. ;)
it helped to fix it. What the fix does it it does the same for the node numbers before the start node than what is done for the gaps. It does include them in all the helper vectors, but ignores them at colorizing eventually.
HarryvL
Post by HarryvL »
Hi Bernd,
I ran a few cases and it seems the problem is now fixed in "CalculiX_static_results > Result_mesh". However, a problem still exists for VTK ... both creating a Pipeline and Exporting to VTK make FreeCAD crash for "OUTPUT=3D.
bernd
Post by bernd »
Yes thats true. I did not look into this yet.
