Stress Result in Shells
bernd
Re: Stress Result in Shells
Postby bernd » Sun Mar 25, 2018 9:25 pm
related issue #2873 in case of the reason of the renumbering.
UR_
Postby UR_ » Sun Mar 25, 2018 9:32 pm
I think, vtk isn't the problem at 1st place.
Please run ccx and generate a new Calculix_static_results object.
Have a look at plot of max principal stresses. They are looking good.
But after saving and reloading, same plot looks weird. :shock:
EDIT: exporting "weird" looking result object to vtk, looks good in paraview ;)
Maybe heap corruption is done while producing result object.
With saving and reloading bad allocs are cleaned out.
Unfortunately vtk runs into this mess if done otherwise.
HarryvL
Postby HarryvL » Mon Mar 26, 2018 12:58 am
bernd wrote:
Sun Mar 25, 2018 8:28 pm
it chrashes here too.
BUT there is a workaround. Export the result to vtk file and import the vtk file as vtk pipline (or use the exported vtk file in paraview) will work :D
Neverless I will have a look at the crash.
bernd
If I re-run my original file (posted earlier) and try to export the Result as VTK then FC crashes. No different from trying to create a VTK Pipeline
HarryvL
Postby HarryvL » Mon Mar 26, 2018 1:27 am
bernd wrote:
Sun Mar 25, 2018 8:37 pm
would you guys do my a favor an try this ...
- load file https://forum.freecadweb.org/download/file.php?id=55290
- recalculate the analysis
- save the file
- close the file
- reopen the file
- create a vtk pipeline from the result object
- it works :o :shock: at least it does for me :mrgreen:
This indeed doesn't crash, but the results are wrong:
Then closing and opening the CalculiX_static_results object again, FreeCAD started to misbehave. :twisted: Part of the model was gone and zooming out to fit on screen did not work (froze for a while and came back with an empty screen). Could there be something wrong with an array index - trying to access beyond array bounds?
HarryvL
Postby HarryvL » Mon Mar 26, 2018 1:38 am
Here an example of mis-behaviour:
bernd
Postby bernd » Mon Mar 26, 2018 7:43 am
the resultmesh is renumbered at save and reload, but the node numbers attribute in result object has still the old not renumbered numbers ...
bernd
Postby bernd » Wed Mar 28, 2018 5:36 pm
Poisson ratio fix is in master. git commit 8717edb98
bernd
Postby bernd » Wed Mar 28, 2018 5:37 pm
To export to vtk or to create a vtk pipeline the mesh nodes should not have gaps. Attached simple mesh will crash freecad:
import Fem
path = '/home/hugo/Desktop/'
nodes = Fem.FemMesh()
nodes.addNode( 0,  0, 0, 1)
nodes.addNode( 6, 12, 0, 3)
nodes.write(path + 'nodes.vtk')
https://github.com/FreeCAD/FreeCAD/blob ... #L446-L455
OS: Debian GNU/Linux 9.4 (stretch)
Version: 0.17.13470 (Git)
Build type: Debug
Hash: 656a669cb0dc3d2d3becf20a5330531233b56834
Python version: 2.7.13
OCC version: 7.0.0
Locale: German/Switzerland (de_CH)
Site Admin
Postby wmayer » Sun Apr 01, 2018 4:03 pm
I can confirm the crash but I have no idea why. It happens inside exportFemMeshFaces where it tries to destroy the grid. However, the ref counter is set to three at this point and it shouldn't try to delete it.
bernd
Postby bernd » Tue Apr 03, 2018 3:55 pm
It somehow seams to crash here: https://github.com/FreeCAD/FreeCAD/blob ... s.cpp#L453 If all other following code in exportVTKMesh() is commented ( this one: https://github.com/FreeCAD/FreeCAD/blob ... #L455-L461 ) FreeCAD still crashes ...
https://github.com/berndhahnebach/FreeC ... fb6934c967
