I have the situation that i want to add a force in the y direction but my model don't have any edges on it or planes thru it...
Would it be possible to set axis from part design in the direction option?
just create a line in the direction of your need with Part --> primitives tool
AFAIK you can make lines with PDN too https://forum.freecadweb.org/viewtopic. ... 36#p221331
The funny part is: PDN uses hierarchical placements from so called "tip" to root.
