non uniform distributed load
Taufeeq2
Postby Taufeeq2 » Fri Mar 30, 2018 12:47 pm
Does anyone know of a way of applying a non uniform distributed load on a face using freecad?
I have tried reading the calculix manual but couldnt get my head around the way calculix code is written.
Any help would be greatly appreciated
Re: non uniform distributed load
Postby chrisb » Fri Mar 30, 2018 12:56 pm
Hi Taufeeq1, welcome to the FreeCAD forum.
I have moved your topic to the FEM forum.
bernd
Postby bernd » Sat Mar 31, 2018 6:54 am
what exactly do you mean by a nonuniform face load?
UR_
Postby UR_ » Sat Mar 31, 2018 10:09 am
beam load q(x).png (10.49 KiB) Viewed 1325 times
Jee-Bee
Postby Jee-Bee » Sat Mar 31, 2018 12:29 pm
Worst case you can make it you're self with a CLOAD or DLOAD just add on every node or face another load.
Not nice but i wasn't able to see all the examples... http://www.feacluster.com/CalculiX/ccx_ ... ode403.php
bernd
Postby bernd » Sun Apr 01, 2018 9:40 am
what could be don as work around:
- split the face into new faces, by sketcher and boolean fragments
- use uniform face load on each face
ulrich1a
Postby ulrich1a » Sun Apr 01, 2018 10:11 am
An approach to program this, would be something similar like the mesh settings for GMSH. So one can set values at the edges of a face and an interpolation routine would be needed, that sets the intermediate values for all mesh-faces or nodes of this face.
Openfoam allows to define a field, for example a flow field for the inlet of some tube that has the velocity distribution of a laminar flow. Such a field is than used to set the boundary conditions at an cross section of that tube.
This looks like a feature request with a lot of programming work required.
Ulrich
Jee-Bee
Postby Jee-Bee » Tue Apr 03, 2018 9:28 am
I would aasume u need this: http://www.feacluster.com/CalculiX/ccx_ ... de241.html
But there is no uniformal distributed option in it....
bernd
Postby bernd » Tue Apr 03, 2018 2:59 pm
we would not need it, we could calculate the dload for every element face.
UR_
Postby UR_ » Wed Apr 18, 2018 5:40 pm
Attached one can find a small example, howto apply a nonuniform pressure load.
There is plate from shell elements with a circluar shaped face.
The face at the center should get a cosine shaped pressure distribution.
cosine shaped pressure distribution.gif (367.89 KiB) Viewed 1133 times
workflow:
- ensure Edit->Preferences->FEM->Calculix->InputFileSplitting is checked
- load "cosine shaped pressure load.FCStd"
- delete object "NonUniformLoad"
- activate Analysis
- "Write inp file" in CalculiXccxTools task view
- execute macro "ApplyNonUniformLoad.FCMacro" and wait for finishing (see report view)
- "Run Calculix" in CalculiXccxTools task view
result:
file:
(960.21 KiB) Downloaded 57 times
macro:
(3.86 KiB) Downloaded 50 times
import Draft
import Part
import os
import sys
import tempfile
import math
# pressure load distribution p = f(x,y,z)  [MPa]
def UniformLoad(x, y, z):
    p = math.cos (math.sqrt (x*x + y*y) / 20 * math.pi / 2)
    return p
doc = App.ActiveDocument
mesh =  doc.getObjectsByLabel("FEMMeshGmsh")[0].FemMesh
## hardcoded user input ##
LoadFace = doc.getObject("CompoundFilter").Shape.Face3          # face to apply pressure load
LoadDisplayScale = 20.                                           # scaling of vectors for pressure visualization [mm/MPa}
ElementFaces = mesh.getFacesByFace(LoadFace)
print ("No of Element Faces: " + str(len(ElementFaces)))
print ("Element Faces: " + str(ElementFaces))
# get WorkingDir
WorkingDir = FreeCAD.ParamGet('User parameter:BaseApp/Preferences/Mod/Fem/General').GetString("WorkingDir")
if not WorkingDir:
     WorkingDir = doc.getObject("CalculiXccxTools").WorkingDir
if not WorkingDir:
     WorkingDir =  tempfile.gettempdir()
print ("WorkingDir: " + WorkingDir)
if not WorkingDir:
     raise SystemExit
# create INP file pressure section
# has to be included into master INP file
with open (WorkingDir + "/FemMeshGmsh_Pressure.inp", "w") as f:
    f.write ("***********************************************************\n")
    f.write ("** Element + CalculiX face + load in [MPa]\n")
    f.write ("** written by " + (os.path.basename(__file__)) + "\n")
    f.write ("** FemConstraintPressure\n")
    f.write ("*DLOAD\n")
    f.write ("** FemConstraintPressure: face load\n")
    VGroup = Draft.makeVisGroup()
    VGroup.Label = "NonUniformLoad"
    VGroup.ViewObject.LineColor = (0.000,1.000,0.000)
    VGroup.ViewObject.ShapeColor = (1.000,0.000,0.000)
    VGroup.ViewObject.Transparency = 80
    for n in ElementFaces:
        Gui.updateGui()
        Nodes = mesh.getElementNodes(n)
        print ("Nodes of Elem (" + str(n) + "): " + str(Nodes))
        Points = []
        if len(Nodes) == 3:
            # for 1st order faces
            Points.append(mesh.getNodeById(Nodes[0]))
            Points.append(mesh.getNodeById(Nodes[1]))
            Points.append(mesh.getNodeById(Nodes[2]))
        elif len(Nodes) == 6:
            # for 2nd order faces
            Points.append(mesh.getNodeById(Nodes[3]))
            Points.append(mesh.getNodeById(Nodes[4]))
            Points.append(mesh.getNodeById(Nodes[5]))
        else:
            print ("Error: ElementFace: " + str(n) + " NodeCount: " + str(len(Nodes)) + " Hint: Only 3 or 6 nodes per face allowed")
            break
        print (Points)
        Face = Draft.makeWire (Points, closed = True, face = True)
        VGroup.addObject(Face)
        Xm = Face.Shape.CenterOfMass.x
        Ym = Face.Shape.CenterOfMass.y
        Zm = Face.Shape.CenterOfMass.z
        print ("CenterOfMass: X" + str(Xm) + " Y" + str(Ym) + " Z" + str(Zm))
        ElementFaceLoad = UniformLoad(Xm, Ym, Zm)
        print ("ElementFaceLoad: " + str(ElementFaceLoad))
        normal = Face.Shape.normalAt(0,0)
        print ("Face normal: " + str(normal))
        # visualize pressure vector
        Load = Draft.makeLine(Face.Shape.CenterOfMass, LoadDisplayScale * ElementFaceLoad * normal + Face.Shape.CenterOfMass)
        VGroup.addObject(Load)
        # write to INP file
        f.write (str(n) + ",P," + str(ElementFaceLoad)+ "\n")
        print ("==============================")
print "ready"
done with:
Version: 0.18.13516 (Git)
Hash: 7101d9a89d49ed718d42611a81f1097b723e5ad2
Python version: 2.7.14
OCC version: 7.2.0
