Hello Forum members
I wanted to make a few FEM calculations but failed in setting the material.
Is there any chance to modify the units?
E.g. Density = kg/mm³
That`s not very common.
Besides, I can`t insert a density at all. Aluminium has a density of 2700 kg/m³.
That would be 0.0000027 kg/mm³. Always after enter this value, it appears 0.00 kg/mm³.
Also the units for specific heat and conductivity are very un-common.
Can I change this anywhere?
Thanks for help.
Regards
Christian
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
Material characteristics and units
Re: Material characteristics and units
Hi and welcome to FreeCAD FEMMrRossi wrote: ↑Tue Apr 17, 2018 2:59 pm I wanted to make a few FEM calculations but failed in setting the material.
Change the unit system to m/kg ... in the preferences would work. But this is a bit to much IMHO. What works for me too is just change the unit in the material task panel. It does not convert the value. Means you need to change the value too. But it keeps the changed value and unit.
Bernd
Hi bernd
Already tried to change the unit in directly in the panel. Doesn't work. Always jumps back to initial units.
Regards
Christian
Regards
Christian
Failed to setting the material. Man...
Have you done your work in the cfd-wb after hours of discussions?
https://forum.freecadweb.org/viewtopic. ... 31#p225631
There is also a setting for # decimals:
- Capture.PNG (14.81 KiB) Viewed 686 times
Hello
@thschrader:
No, I haven`t. I haven`t found time to test. April is a very busy month, at home and on work too.
Hope I can do this in the next weeks.
Regards
Christian
@thschrader:
Regards
Christian
