No mesh
UR_
Re: No mesh
Post by UR_ »
JV_3D wrote: Thu Jun 21, 2018 5:18 am How do you export the mesh in .geo format from FreeCAD?
FreeCAD writes out a .geo file after hitting [Apply] button from task panel "Fem mesh by Gmsh"
screenshot task panel.png (19.66 KiB) Viewed 811 times
In report view something like this appears:
Please note red marked text, here you will find generated .geo file
We are going to start Gmsh FEM mesh run!
Part to mesh: Name --> Box, Label --> Cube, ShapeType --> Solid
CharacteristicLengthMax: 1e+22
CharacteristicLengthMin: 0.0
ElementOrder: 2
ElementDimension: 3
c:\users\aio\appdata\local\temp\Box_Geometry.brep
c:\users\aio\appdata\local\temp\Box_Mesh_TmpGmsh.unv
c:\users\aio\appdata\local\temp\shape2mesh.geo
C:/Program Files/FreeCAD/bin/gmsh_3.0.6.exe
Group meshing for analysis.
Empty reference: SolidMaterial
One material with no reference shapes. No need to make a group for materials.
{'FemConstraintFixed': ['Face1'], 'FemConstraintForce': ['Face2']}
Start: ViewProviderFEMMeshBuilder::createMesh() =================================
0.000000: Start build up 872 face helper
0.000000: Start eliminate internal faces SIMPLE
0.000000: Start build up node map
0.000000: Start set point vector
0.000000: Start count triangle size
NumTriangles:800
0.000000: Start build up triangle vector
0.000000: Start build up edge vector
NumEdges:1200
0.000000: Finish =========================================================
The Part should have a pretty new FEM mesh!
On the other hand your Gmsh.exe is a outdated build from 2016!
Please update to version 3.0.6
As you can see in these about dialogs:
FreeCAD is build against OCC 7.2.0, while your Gmsh is build against OCC 6.8.0 :shock:
This is pretty dangerous.
JV_3D
Re: No mesh
Post by JV_3D »
UR_ wrote: Fri Jun 22, 2018 1:23 pm
ElementOrder: 2
ElementDimension: 3
NumTriangles:800
NumEdges:1200
Well, I resolved by 'saving as', selecting unv AND writing .unv in the name, without writing and specifying the extension it did not work.
How dangerous is this? I download the Gmsh available in the Software manager from Mint
bernd
Re: No mesh
Post by bernd »
normally it should not be a problem to use a FreeCAD and gmesh with different OpenCascade versions. For exchange between them brep and unv files are used. These file formats should work independent from OpenCascade versions. IMHO.
@JV_3D:
have you solved the issue? Does Gmsh works inside FreeCAD for you?
bernd
omi06
Re: No mesh
Post by omi06 »
I'm having the same problem as you JV_3D, did you find a solution ?
Thank you
Romain
