Plotting of Concrete Reinforcement Ratio
HarryvL
Re: Plotting of Concrete Reinforcement Ratio
Postby HarryvL » Thu May 24, 2018 7:15 pm
HarryvL wrote:
Thu May 24, 2018 5:38 pm
bernd wrote:
Thu May 24, 2018 4:07 pm
HarryvL wrote:
Thu May 24, 2018 10:11 am
I have not tried Bernd, but yes that's what is done internally in CCX. 1D and 2D elements get expanded into 3D first and then a beam or shell hinge is implemented through a knot. Not sure if/how this can be specified or controlled by the CCX user.
Alternatively you could try to connect two solids at a common edge? As solid element nodes have no rotational stiffness, this would effectively create a hinge.
We may missunderstood. About 1D and 2D analysis this is known ...
No I mean assumed you have a slab and a wall in 3D solid elements, but for some reason there should be a weak connection because there is only really rare reinforcement. Thus one needs to modell a hinge connection between them. But a hinge in 3D analysis is not possible. Thus my idea was to add a material between them with some weak youngs modulus. Or is it better to split the objects and connect the mesh faces by a special element? Or only connect the at an edge and not with a face.
bernd
I would try the last option first.
like this:
Test103.fcstd
(99.15 KiB) Downloaded 21 times
bernd
Postby bernd » Thu May 24, 2018 7:42 pm
Since the geometry has to be changed it will be difficault to do this on a building by just ckicking the two objects and say hinged ... Mhh, good so far ... sorry for entering the topic with this hinged stuff.
HarryvL
Postby HarryvL » Thu May 24, 2018 9:10 pm
Massive 4x4x2m foundation block (C30/37) loaded by 10MN load. This time not so easy to work out reinforcement with traditional techniques ?!
ReRa_x and ReRa_y should be symmetric, which they are. MC=0, so no shear or crushing failure.
HarryvL
Postby HarryvL » Thu May 24, 2018 9:25 pm
HarryvL
Postby HarryvL » Thu May 24, 2018 9:54 pm
And a 4.0x4.0x0.15m simply supported floor with a 1.0x2.0m hole for a staircase, loaded by self weight and 4kN/m2 live load.
HarryvL
Postby HarryvL » Fri May 25, 2018 12:16 am
bernd wrote:
Thu May 24, 2018 4:04 pm
basically yes, but you did not try the code, did you ;)
if obj.Name[:13] == "SolidMaterial":
you can use
if isDerivedFrom(obj, 'Fem::Material'):
we may sould make all this on an explizit example, this would be much more simple to understand ...
so this is how far I got with importToolsFem.py:
import femmesh.meshtools
result_mesh = FreeCAD.ActiveDocument.Result_mesh
            for obj in FreeCAD.ActiveDocument.Objects:
#              if isDerivedFrom(obj, 'Fem::Material'):
                    if obj.Material.get('Name') != "Concrete":
                        print("NOT CONCRETE")
                        for ref in obj.References:
                            non_concrete_nodes = femmesh.meshtools.get_femnodes_by_refshape(result_mesh, ref)
                            for ncn in non_concrete_nodes:
                                results.ReinforcementRatio_x[ncn]  = 0.
                                results.ReinforcementRatio_y[ncn]  = 0.
                                results.ReinforcementRatio_z[ncn]  = 0.
                                results.MohrCoulomb[ncn] = 0.
                    else:
                        print("CONCRETE")
however, this gives the following error on loading the FRD:
File "/home/harry/FC_MM/Mod/Fem/femmesh/meshtools.py", line 88, in get_femnodes_by_refshape
    nodes += femmesh.getNodesBySolid(r)
AttributeError: 'FeaturePython' object has no attribute 'getNodesBySolid'
I get the same result when I pass the FEMMeshGmsh.
HarryvL
Postby HarryvL » Fri May 25, 2018 6:45 am
@Bernd, I use your mixed mesh branch for this development. Could it have to do with that?
bernd
Postby bernd » Fri May 25, 2018 9:13 am
to be sure it is not this one I rebased it on FreeCAD master just ATM.
bernd
Postby bernd » Fri May 25, 2018 9:55 am
try this ...
result_mesh = FreeCAD.ActiveDocument.Result_mesh.FemMesh
non_concrete_nodes = []
    if obj.isDerivedFrom('App::MaterialObjectPython'):
        if obj.Material.get('Name') != "CONCRETE":
        else:
            print("CONCRETE")
print(non_concrete_nodes)
is the document object but you need to pass the FemMesh and not the document object. Thus:
HarryvL
Postby HarryvL » Fri May 25, 2018 2:59 pm
Thanks Bernd. It works. Let the testing continue :D
