Plotting of Concrete Reinforcement Ratio
HarryvL
Re: Plotting of Concrete Reinforcement Ratio
Postby HarryvL » Sun May 27, 2018 9:19 pm
HarryvL wrote:
Thu May 24, 2018 4:55 am
HarryvL wrote:
Thu May 24, 2018 4:41 am
... Results look credible and in line with applied reinforcement.
Worth seeing how reinforcement ratio translates into required area of bars, but what is immediately clear from the first plot:
FreeCAD: Required Ratio_x top ~ 1.3 * Ratio_x_mid_span
Design: 4 Ø 12 at top vs. 3 Ø 12 at mid span, so indeed 1:1.3
An example of how the plots could help the designer...
Above the central support, the required reinforcement in x-direction follows from the following plot:
The required area of steel per area of concrete (on x-section x=constant) varies over the height. This is of course not practical and the x-section needs to be divided in zones with a single reinforcement ratio. In some cases it may desirable to apply several layers of steel in such way, but in this practical example of a beam only a single layer is applied. So in this the case of one layer, the average steel area required is:
As = Rho_av * Height_of_Zone * Width_of_Zone * Material_Factor = 0.5*0.012*200*200*1.15 = 276 mm^2
3 Ø 10 gives 237 mm^2 (insufficient)
3 Ø 12 give 340 mm^2 (sufficient)
To be placed roughly near the center of gravity of the zone (~200/3 = 65mm from the top).
Similar considerations can be applied for the other locations and the other reinforcement ratios.
Again, I need to stress here that I am not a qualified concrete structural engineer, so please don't take this as professional advice, but an invitation for a discussion...
thschrader
Postby thschrader » Mon May 28, 2018 8:43 am
No problem.
When designing the reinforcement of concrete structures, there is no "perfect" solution.
For example, when I use my commercial software, I must define the concrete cover of the
reinforcement (which defines the position of the rebars) before running the calculation.
There are some other things to keep in mind:
German DIN manuals for concrete design uses a "gliding" safety factor between 1,75-2,1, depending on
the strain of the compressed concrete zone. And you can enable the options
"limit crack width" and/or "limit deflection", which has an influence on the total reinforcement.
Do you know the "integrate variables" filter in paraview? You can slice through the threshold plot
(positive Sxx-stresses) and use the integrate filter which gives the total force in the zone.
In my case it gives approx 120 kN. When calculating the total reinforcment including safety-factor of 1,75,
I get a total reinforcement of 4,2 cm^2. My software calculated 4,46 cm^2, fits very well.
HarryvL
Postby HarryvL » Mon May 28, 2018 9:04 am
Thanks Thomas. I did not apply a safety factor nor did I consider any of the other criteria you describe. I will have another look - also at the integrate filter, which sounds like a cool option.
HarryvL
Postby HarryvL » Mon May 28, 2018 9:31 am
Now with SF=1.75 instead of Material Factor = 1.15:
As = Rho_av * Height_of_Zone * Width_of_Zone * Safety_Factor = 0.5*0.012*200*200*1.75 = 420 mm^2
3 Ø 12 gives 340 mm^2 (insufficient)
4 Ø 12 give 452  mm^2 (sufficient)
I guess the real advantage of using FreeCAD and reinforcement ratios only becomes apparent for more complex geometries (e.g. compound shapes, floors/walls with penetrations, complex support arrangements, massive 3D, etc.) and loads (e.g. temperature loading in massive bodies, earth quake, support subsidence, etc.)
FATHI RAMMAH
Postby FATHI RAMMAH » Tue May 29, 2018 11:31 am
hello Harryvl
what is the standard reinforcement design code do you use to calculate the reinforcement ratio....thanks?
HarryvL
Postby HarryvL » Tue May 29, 2018 11:58 am
I use this:
http://heronjournal.nl/53-4/3.pdf
It's not related to any specific code.
FATHI RAMMAH
Postby FATHI RAMMAH » Tue May 29, 2018 2:59 pm
I use this:
HarryvL
Postby HarryvL » Wed May 30, 2018 7:53 am
For those who want to know more about this approach in design, the following is worth reading:
https://www.researchgate.net/profile/El ... ethods.pdf
HarryvL
Postby HarryvL » Fri Jul 06, 2018 4:25 pm
bernd wrote:
Fri May 25, 2018 9:55 am
try this ...
import femmesh.meshtools
result_mesh = FreeCAD.ActiveDocument.Result_mesh.FemMesh
non_concrete_nodes = []
for obj in FreeCAD.ActiveDocument.Objects:
    if obj.isDerivedFrom('App::MaterialObjectPython'):
        if obj.Material.get('Name') != "CONCRETE":
            print("NOT CONCRETE")
            for ref in obj.References:
                non_concrete_nodes = femmesh.meshtools.get_femnodes_by_refshape(result_mesh, ref)
        else:
            print("CONCRETE")
print(non_concrete_nodes)
is the document object but you need to pass the FemMesh and not the document object. Thus:
I thought I had this issue solved, but running another test today on a mesh with a total of 113 nodes results in a list of 761 concrete nodes, i.e. femmesh.meshtools.get_femnodes_by_refshape(result_mesh, ref) == 761. Regenerating the mesh with more or less nodes makes no difference.
HarryvL
Postby HarryvL » Fri Jul 06, 2018 4:30 pm
I started from scratch and now get 100 concrete nodes.
By the way, I forgot to mention that 1 block is made of steel and 1 made of concrete. The interface between the two blocks contains 13 nodes and the grand total is 113. So I would expect "non_concrete_nodes = femmesh.meshtools.get_femnodes_by_refshape(result_mesh, ref)" to result in a list of 50 or 63 nodes, depending on whether or not the interface counts as steel or concrete. But it actually returns nodes 1..100.
The search continues ...
