Plotting of Concrete Reinforcement Ratio
bernd
Re: Plotting of Concrete Reinforcement Ratio
Postby bernd » Sat Jul 07, 2018 7:24 am
AFAIK the 13 nodes of the interface face should be returned in both, in the steel box (solid) and in the concrete box (solid).
bernd
Postby bernd » Sat Jul 07, 2018 7:25 am
would you post a file to test and to be sure we gone ude the same file for testing
bernd
Postby bernd » Sat Jul 07, 2018 7:27 am
deactivate groupmeshing in FEM prefs!
HarryvL
Postby HarryvL » Sat Jul 07, 2018 3:04 pm
Thanks Bernd, here it is:
CON_NONCON.fcstd
(54.39 KiB) Downloaded 20 times
PS: I deactivated group meshing, regenerated GMSH and reran CCX. On return from CCX I print in importToolsFem.py the following for material objects with name "concrete":
concrete_nodes = femmesh.meshtools.get_femnodes_by_refshape(result_mesh, ref)
print("concrete nodes: {}".format(concrete_nodes))
This prints a list of length 761 ((below in full length :D). Although this may even be truncated, because the print out ends in ", 761L," rather than ", 761L]"
concrete nodes: [1L, 2L, 3L, 4L, 5L, 6L, 7L, 8L, 13L, 14L, 15L, 16L, 17L, 18L, 19L, 20L, 21L, 22L, 23L, 24L, 25L, 26L, 27L, 28L, 29L, 30L, 31L, 32L, 33L, 34L, 35L, 36L, 37L, 38L, 39L, 40L, 41L, 42L, 43L, 44L, 45L, 46L, 47L, 48L, 49L, 50L, 51L, 52L, 53L, 54L, 55L, 56L, 57L, 58L, 59L, 60L, 61L, 62L, 63L, 64L, 65L, 66L, 67L, 68L, 69L, 70L, 71L, 72L, 73L, 74L, 75L, 76L, 77L, 78L, 79L, 80L, 81L, 82L, 83L, 84L, 85L, 86L, 87L, 88L, 89L, 90L, 91L, 92L, 93L, 94L, 95L, 96L, 97L, 98L, 99L, 100L, 101L, 102L, 103L, 104L, 105L, 106L, 107L, 108L, 109L, 110L, 111L, 112L, 113L, 114L, 115L, 116L, 117L, 118L, 119L, 120L, 193L, 194L, 195L, 196L, 197L, 198L, 199L, 200L, 201L, 202L, 203L, 204L, 205L, 206L, 207L, 208L, 209L, 210L, 211L, 212L, 213L, 214L, 215L, 216L, 217L, 218L, 219L, 220L, 221L, 222L, 223L, 224L, 225L, 226L, 227L, 228L, 229L, 230L, 231L, 232L, 233L, 234L, 235L, 236L, 237L, 238L, 239L, 240L, 241L, 242L, 243L, 244L, 245L, 246L, 247L, 248L, 249L, 250L, 251L, 252L, 253L, 254L, 255L, 256L, 257L, 258L, 259L, 260L, 261L, 262L, 263L, 264L, 265L, 266L, 267L, 268L, 269L, 270L, 271L, 272L, 273L, 274L, 275L, 276L, 277L, 278L, 279L, 280L, 281L, 282L, 283L, 284L, 285L, 286L, 287L, 288L, 289L, 290L, 291L, 292L, 293L, 294L, 295L, 296L, 297L, 298L, 299L, 300L, 301L, 302L, 303L, 304L, 305L, 306L, 307L, 308L, 309L, 310L, 311L, 312L, 313L, 314L, 315L, 316L, 317L, 318L, 319L, 320L, 321L, 322L, 323L, 324L, 325L, 326L, 327L, 328L, 329L, 330L, 331L, 332L, 333L, 334L, 335L, 336L, 337L, 338L, 339L, 340L, 341L, 342L, 343L, 344L, 345L, 346L, 347L, 348L, 349L, 350L, 351L, 352L, 353L, 354L, 355L, 356L, 357L, 358L, 359L, 360L, 361L, 362L, 363L, 364L, 365L, 366L, 367L, 368L, 369L, 370L, 371L, 372L, 373L, 374L, 375L, 376L, 377L, 378L, 379L, 380L, 381L, 382L, 383L, 384L, 385L, 386L, 387L, 388L, 389L, 390L, 391L, 392L, 393L, 394L, 395L, 396L, 397L, 398L, 399L, 400L, 401L, 402L, 403L, 404L, 405L, 406L, 407L, 408L, 409L, 410L, 411L, 412L, 413L, 414L, 415L, 416L, 417L, 418L, 419L, 420L, 421L, 422L, 423L, 424L, 425L, 426L, 427L, 428L, 429L, 430L, 431L, 432L, 433L, 434L, 435L, 436L, 437L, 438L, 439L, 440L, 441L, 442L, 443L, 444L, 445L, 446L, 447L, 448L, 449L, 450L, 451L, 452L, 453L, 454L, 455L, 456L, 457L, 458L, 459L, 460L, 461L, 462L, 463L, 464L, 465L, 466L, 467L, 468L, 469L, 470L, 471L, 472L, 473L, 474L, 475L, 476L, 477L, 478L, 479L, 480L, 481L, 482L, 483L, 484L, 485L, 486L, 487L, 488L, 489L, 490L, 491L, 492L, 493L, 494L, 495L, 496L, 497L, 498L, 499L, 500L, 501L, 502L, 503L, 504L, 505L, 506L, 507L, 508L, 509L, 510L, 511L, 512L, 513L, 514L, 515L, 516L, 517L, 518L, 519L, 520L, 521L, 522L, 523L, 524L, 525L, 526L, 527L, 528L, 529L, 530L, 531L, 532L, 533L, 534L, 535L, 536L, 537L, 538L, 539L, 540L, 541L, 542L, 543L, 544L, 545L, 546L, 547L, 548L, 549L, 550L, 551L, 552L, 553L, 554L, 555L, 556L, 557L, 558L, 559L, 560L, 561L, 562L, 563L, 564L, 565L, 566L, 567L, 568L, 569L, 570L, 571L, 572L, 573L, 574L, 575L, 576L, 577L, 578L, 579L, 580L, 581L, 582L, 583L, 584L, 585L, 586L, 587L, 588L, 589L, 590L, 591L, 592L, 593L, 594L, 595L, 596L, 597L, 598L, 599L, 600L, 601L, 602L, 603L, 604L, 605L, 606L, 607L, 608L, 609L, 610L, 611L, 612L, 613L, 614L, 615L, 616L, 617L, 618L, 619L, 620L, 621L, 622L, 623L, 624L, 625L, 626L, 627L, 628L, 629L, 630L, 631L, 632L, 633L, 634L, 635L, 636L, 637L, 638L, 639L, 640L, 641L, 642L, 643L, 644L, 645L, 646L, 647L, 648L, 649L, 650L, 651L, 652L, 653L, 654L, 655L, 656L, 657L, 658L, 659L, 660L, 661L, 662L, 663L, 664L, 665L, 666L, 667L, 668L, 669L, 670L, 671L, 672L, 673L, 674L, 675L, 676L, 677L, 678L, 679L, 680L, 681L, 682L, 683L, 684L, 685L, 686L, 687L, 688L, 689L, 690L, 691L, 692L, 693L, 694L, 695L, 696L, 697L, 698L, 699L, 700L, 701L, 702L, 703L, 704L, 705L, 706L, 707L, 708L, 709L, 710L, 711L, 712L, 713L, 714L, 715L, 716L, 717L, 718L, 719L, 720L, 721L, 722L, 723L, 724L, 725L, 726L, 727L, 728L, 729L, 730L, 731L, 732L, 733L, 734L, 735L, 736L, 737L, 738L, 739L, 740L, 741L, 742L, 743L, 744L, 745L, 746L, 747L, 748L, 749L, 750L, 751L, 752L, 753L, 754L, 755L, 756L, 757L, 758L, 759L, 760L, 761L,
HarryvL
Postby HarryvL » Sat Jul 07, 2018 3:19 pm
And here is the full code segment for identifying concrete nodes ...
ic[node]==0 means undecided
ic[node]==1 means concrete
ic[node]==2 means not concrete
                for obj in FreeCAD.ActiveDocument.Objects:
                    if obj.isDerivedFrom('App::MaterialObjectPython'):
                        print("object: {}".format(obj))
                        print("object Name: {}".format(obj.Material.get('Name')))
                        print("object.References: {}".format(obj.References))
                        if obj.Material.get('Name') == "Concrete":
                            print("CONCRETE")
                            if obj.References == []:
                                for iic in range(nsr):
                                    if ic[iic] == 0:
                                        ic[iic] = 1
                            else:
                                for ref in obj.References:
                                    print(type(concrete_nodes))
                                    for cn in concrete_nodes:
                                        ic [cn-1] = 1
                        else:
                            print("NOT CONCRETE")
                                    if ic[iic] == 0:
                                        ic[iic] = 2
                            else:
                                    non_concrete_nodes = femmesh.meshtools.get_femnodes_by_refshape(result_mesh, ref)
                                    for ncn in non_concrete_nodes:
                                        ic [ncn-1] = 2
bernd
Postby bernd » Mon Jul 09, 2018 4:27 am
open your file and run the following code ...
for g in App.ActiveDocument.FEMMeshGmsh.FemMesh.Groups:
    print(App.ActiveDocument.FEMMeshGmsh.FemMesh.getGroupName(g))
I get for your file:
...     print(App.ActiveDocument.FEMMeshGmsh.FemMesh.getGroupName(g))
FemConstraintFixed_Nodes
FemConstraintFixed_Faces
FemConstraintPressure_Nodes
FemConstraintPressure_Faces
Which seams you have group meshing activated in FEM prefs. If there are groups these groups will be taken. Means to be on the save side in any case deactivate automatic group meshing for analysis reference shapes.
I will have a look at the file anyway ...
bernd
Postby bernd » Mon Jul 09, 2018 4:42 am
my file without groups attached ... I opened your file remeshed without groups meshing, deleted all results and rerun ccx.
my (your) code (which only partially runs for me) attached ...
import femmesh
result_mesh = App.ActiveDocument.Result_mesh.FemMesh
            print("CONCRETE")
                    if ic[iic] == 0:
                        ic[iic] = 1
            else:
                        ic [cn-1] = 1
        else:
                    if ic[iic] == 0:
                        ic[iic] = 2
            else:
                        ic [ncn-1] = 2
output:
object: <App::MaterialObjectPython object>
object Name: Concrete
object.References: [(<Part::PartFeature>, ('Solid1',))]
CONCRETE
  ReferenceShape ... Type: Solid, Object name: BooleanFragments, Object label: BooleanFragments, Element name: Solid1
<type 'list'>
concrete nodes: [1L, 2L, 3L, 4L, 5L, 6L, 7L, 8L, 13L, 14L, 15L, 16L, 17L, 18L, 19L, 20L, 21L, 22L, 23L, 24L, 33L, 34L, 35L, 36L, 37L, 38L, 39L, 40L, 41L, 42L, 43L, 44L, 45L, 46L, 47L, 48L, 49L, 50L, 51L, 52L, 53L, 54L, 55L, 56L, 57L, 58L, 59L, 60L, 61L, 62L, 88L, 89L, 90L, 91L, 92L, 93L, 94L, 95L, 96L, 97L, 98L, 99L, 100L]
  File "<input>", line 18, in <module>
NameError: name 'ic' is not defined
how do I get ic, nsr etc ? Are these empty lists I need to create before?
CON_NONCON_bernd1.fcstd
(54.44 KiB) Downloaded 17 times
HarryvL
Postby HarryvL » Mon Jul 09, 2018 9:16 am
... how do I get ic, nsr etc ? Are these empty lists I need to create before?
Thanks for doing this Bernd. The piece of code follows a few lines of existing code defining nsr and -yes- ic also gets initialized, as follows:
        if 'stress' in result_set:
            stress = result_set['stress']
            nsr=len(stress)
            print("nsr: {}".format(nsr))
            if nsr > 0:
                mstress = []
                prinstress1 = []
                prinstress2 = []
                prinstress3 = []
                shearstress = []
                ps1v = []
                ps2v = []
                ps3v = []
#              HarryvL: from here onward new code for handling of concrete reinforcement
                ic=np.zeros(nsr)
#               HarryvL: addtional arrays to hold reinforcement ratios and mohr coulomb stress
                rhx = []
                rhy = []
                rhz = []
                moc = []
#               HarryvL: determine concrete / non-concrete nodes
                            print("CONCRETE")
                                    if ic[iic] == 0:
                                        ic[iic] = 1
                            else:
                                        ic [cn-1] = 1
                        else:
                                    if ic[iic] == 0:
                                        ic[iic] = 2
                            else:
                                        ic [ncn-1] = 2
                for isv in range(nsr):
                    i=stress.values()[isv]
                    rhox=0.
                    rhoy=0.
                    rhoz=0.
                    mc=0.
                    scxx=i[0]
                    scyy=i[1]
                    sczz=i[2]
                    mstress.append(calculate_von_mises(i))
                    if ic[isv]==1:
#                       HarryvL: calculation of reinforcement ratio
                        rhox, rhoy, rhoz, scxx, scyy, sczz = calculate_rho(i)
#                       HarryvL: for concrete scxx etc. are affected by reinforcement (see calculate_rho(i)). for all other materials scxx etc. are the original stresses
                    prin1, prin2, prin3, shear, psv = calculate_principal_stress(i,scxx,scyy,sczz)
                    prinstress1.append(prin1)
                    prinstress2.append(prin2)
                    prinstress3.append(prin3)
                    shearstress.append(shear)
                    ps1v.append(psv[0])
                    ps2v.append(psv[1])
                    ps3v.append(psv[2])
#                   reinforcement ratios and mohr coulomb criterion
                    rhx.append(rhox)
                    rhy.append(rhoy)
                    rhz.append(rhoz)
                    if ic[isv]==1:
                        mc=calculate_mohr_coulomb(prin1,prin2,prin3)
                    moc.append(mc)
 #                from here onward original code for filling result object
HarryvL
Postby HarryvL » Mon Jul 09, 2018 9:39 am
output:
CONCRETE
<type 'list'>
Bernd, as I reported here: https://forum.freecadweb.org/viewtopic. ... 80#p242996 I also get 100 nodes. However, that is wrong. It should be (113-13)/2+13=65 nodes. There are 113 nodes, half concrete (Solid1), half steel (Solid2) and 13 shared. The print-out indicates there are 100 nodes in Solid1.
HarryvL
Postby HarryvL » Mon Jul 09, 2018 9:42 am
output:
CONCRETE
<type 'list'>
Bernd, as I reported here: https://forum.freecadweb.org/viewtopic. ... 80#p242996 I also get 100 nodes after disabling group meshing. However, that is wrong. It should be (113-13)/2+13=65 nodes. There are 113 nodes, half concrete (Solid1), half steel (Solid2) and 13 shared. The print-out indicates there are 100 nodes in Solid1.
