Principal Stress Plots
HarryvL
Postby HarryvL » Wed Jun 20, 2018 9:41 pm
As a step towards plotting stress trajectories (see https://forum.freecadweb.org/viewtopic. ... 85#p237229) I managed to export principal stress directions to Paraview VTK. Here the example of a block under pure shear conditions:
As can be seen from the Paraview plot, the principal stress directions (+/- 45 degrees) and values (+/- 1000MPa) agree with the applied shear stresses.
To be continued...
HarryvL
Re: Principal Stress Plots
Postby HarryvL » Wed Jun 20, 2018 10:24 pm
... and here the results for a cantilever beam
HarryvL
Postby HarryvL » Wed Jun 20, 2018 11:21 pm
... and a knee joint:
To be continued ...
Jee-Bee
Postby Jee-Bee » Thu Jun 21, 2018 8:45 am
Are you trying to implement the results also in FC or just the calculation method?
HarryvL
Postby HarryvL » Thu Jun 21, 2018 9:37 am
Hi @Jee-Bee. Paraview is a very strong and versatile tool and the link with FC is quite simple. So I am not sure that trying to replicate and maintain Paraview capability inside FreeCAD is the best use of our time. What is your view?
Jee-Bee
Postby Jee-Bee » Thu Jun 21, 2018 9:42 am
I don't have used it. so i don't know what the possebilities are and or how it's working :oops:
HarryvL
Postby HarryvL » Thu Jun 21, 2018 10:08 am
Ah ok. It's well worth a try. Simply export a VTK file from the result object. Paraview is very easy to use. I didn't read any manuals or guides - just Googled a bit and watched some videos :)
thschrader
Postby thschrader » Thu Jun 21, 2018 7:23 pm
Harry, amazing work.
My wish is to see your plots in FC-pipeline results.
"Paraview is very easy to use" :D
HarryvL
Postby HarryvL » Thu Jun 21, 2018 9:04 pm
I will give it a try when I find the time Thomas. It is difficult to choose standard settings though. It takes quite a bit of playing with scale factors, colors, line thicknesses, etc. to get an acceptable result. That flexibility is available to the user in Paraview, but not in the FC VTK pipeline. So I fear that the plots will look clunky, driving people towards Paraview anyway.
Priorities for me at the moment are as follows:
1) leave this and the concrete reinforcement ratios in an orderly state on github, so people can compile and test it
2) try to finish my routine for stress trajectories. I am quite excited about it, because I believe FC would be the first post-processor to have this functionality
3) finish my own 3D elastoplastic collapse solver. This will read regular INP and produce regular FRD) so can simply be called as alternative to CCX
Just too many ideas and too few hours in a day :D
HarryvL
Postby HarryvL » Thu Jun 21, 2018 9:10 pm
A concrete wall 4.00x2.00x0.15m on 0.50x2.00x0.15m columns, loaded by self weight and 1MN distributed load on top ...
Red = Major Principal Stress
Blue = Minor Principal Stress
Green = Intermediate Principal Stress
