Assembly2 assembly meshing of boolion unioned parts min size .1 in or .05" in never seems to finish windows shows not re
schupin
Re: Assembly2 assembly meshing of boolion unioned parts min size .1 in or .05" in never seems to finish windows shows no
Postby schupin » Fri Aug 24, 2018 5:39 am
josheeg wrote:
Fri Aug 24, 2018 1:08 am
Vtk pipeline?
In the FEM workbench, there is a black grid on green background icon.
The tooltip is "create a post processing pipeline from a result object"
josheeg
Postby josheeg » Fri Aug 24, 2018 4:09 pm
Oh so the part of the model that looks like a wireframe mesh is the part past the set limit. This is very helpful to see when the model is past it's normal limits.
josheeg
Postby josheeg » Sat Sep 01, 2018 11:29 pm
So if the frame can scale and I can test the electronics with a lighter frame many it could be made of pvc tube and answer some questions and be moved to the carbon fiber tube frame then. I found some PVC tube properties here. http://www.matweb.com/search/datasheet_ ... 185e92f6f7
