pre-stressed pre/post-tensioned concrete bridge
bernd
Re: pre-stressed pre/post-tensioned concrete bridge
Postby bernd » Mon Aug 20, 2018 4:35 pm
from gmsh documentation on http://gmsh.info/doc/texinfo/gmsh.html
Coherence Mesh;
Removes all duplicate mesh vertices.
HarryvL
Postby HarryvL » Mon Aug 20, 2018 5:55 pm
Final test with contact included looks fine in FreeCAD:
but the same in ParaView shows that after export the nodes get connected again ?!?!?
Anyway, FreeCAD, GMSH and CCX respond in a predictable way.
HarryvL
Postby HarryvL » Mon Aug 20, 2018 6:16 pm
But when I create a small gap, as suggested by UR_, then also PV displays a sensible results:
If there is a Paraview guru amongst us .... is there a Coherence option in ParaView too? It would save me adding small gaps at all contact surfaces, with potential mistakes.
HarryvL
Postby HarryvL » Mon Aug 20, 2018 6:29 pm
Here is the FC file for those who want to play with it :D
Contact_003.fcstd
(647.49 KiB) Downloaded 13 times
bernd
Postby bernd » Mon Aug 20, 2018 7:25 pm
seams not to happen on pipeline creation ...
FreeCAD standard result object:
FreeCAD VTK result pipeline:
but at exporting to VTK file format ... Did you use FreeCAD Vtk pipline export to exort to VTK?
bernd
HarryvL
Postby HarryvL » Mon Aug 20, 2018 7:35 pm
I used File > Export > FEM Result VTK .... is there another way?
HarryvL
Postby HarryvL » Mon Aug 20, 2018 7:38 pm
bernd
Aaaaaaaaa ... the fcstd file I posted was with the small gaps !!!! That works well in ParaView. The one with zero gap gives the sticking nodes.
HarryvL
Postby HarryvL » Mon Aug 20, 2018 7:56 pm
I re-did it with zero gap and you are right (of course :D ) the VTK pipeline works well, but the exported results to ParaView not ?!
Here the file I used for zero gap:
Contact_004.fcstd
(121.76 KiB) Downloaded 12 times
bernd
Postby bernd » Mon Aug 20, 2018 8:37 pm
HarryvL
Postby HarryvL » Mon Aug 20, 2018 9:45 pm
Post tensioning ...
I am running out of time (and patience :twisted: ). I attach the file for those who want to try. This should work "as is". Actual post-tensioning would be the next step, but not before this simple load case converges.
CB_Post_Rev1.fcstd
(133.29 KiB) Downloaded 18 times
CB_Post_Rev1.fcstd
