FEM meshing doesn't generate volume elements
nquantum
Re: FEM meshing doesn't generate volume elements
Postby nquantum » Sat Sep 08, 2018 4:45 pm
Since this is not really related to the topic from the first post and the topic was years old, I made an own topic.
Yes I'm hesitate to open new topic also I think it relate to original topic that why I post here in the beginning. If you think I should post on new topic just tell me ok?
The question is, what exactly would you like to analyze?
I'm designing CNC I want to see how strong the X-base like previous picture. How much it sag from the total weight of y-axis, z-axis? So I determine lower weight or use bigger/smaller aluminum extrusion and/or aluminum plate. Also want to see see weak point of structure so I can move some part here and there to balance or stronger the weak point. I've also have picture of my design here which... have problem of self-intersect , so I cannot do analysis on FEM.
Also :
I recreate file and track down where cause of self-intersect mesh using Gmsh in FEM.
Those bearing block which have hole-trough on top of round-rail create self-intersect. Those two I use fuse union before meshing. If I use intersect those two there is something left! Which should not have since the hole is 10mm radius, rail also 10mm radius. Maybe this is the cause?
If I use simple solid rectangle instead of those hole-trough bearing and fuse union with same round-rail, then no problem of self-intersect.
Back to original question.
- meshing in FEM how to fix self-intersect?
- how to avoid?
- how self-intersect happen? I try to search in forum, there is no clear answer.
Or any suggestion is welcome.
Thank
linear wit block3
linear wit block2
linear wit block1
cnc design
faq1.FCStd
recreate file
(165.04 KiB) Downloaded 7 times
nquantum
Postby nquantum » Sat Sep 08, 2018 4:47 pm
And intersect , rail , block
block
linear rail
linear and block
intersect
nquantum
Postby nquantum » Sun Sep 09, 2018 5:10 am
Maybe part go trough another part can cause problem also?
cnc
