Internal nodes [SOLVED]
EkaitzEsteban
Postby EkaitzEsteban » Wed Sep 12, 2018 2:40 pm
How can I see the internal nodes?
EDIT: SOLVED
bernd
Re: Internal nodes
Postby bernd » Wed Sep 12, 2018 5:27 pm
From the mesh or from results mesh?
EkaitzEsteban
Re: Internal nodes
Postby EkaitzEsteban » Thu Sep 13, 2018 5:25 am
Hello Bernd,
Thank you for your fast response. Maybe I dont explain correctly, it was my first post :).
When I do a mesh, I can visualize the external nodes (on the surface) and it can be "selected" with the mouse. However, I want to be able to select both surface and internal nodes using the mouse.
I attach a coarse mesh of a simple cilinder to see the results.
Version: 0.17.13528 (Git)
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
Python version: 2.7.14
OCC version: 7.2.0
Locale: Spanish/Spain (es_ES)
EkaitzEsteban
Re: Internal nodes [SOLVED]
Postby EkaitzEsteban » Thu Sep 13, 2018 6:54 am
I found a solution. ShowInner = True option allows to see the internal nodes and meshgrid.
The python API code is the following one:
FreeCADGui.getDocument("Unnamed").getObject("FEMMeshNetgen").ShowInner = True
thank you.
Ekaitz.
bernd
Postby bernd » Thu Sep 13, 2018 3:25 pm
Yep thats it, but only if you have less than 50000 Faces. Above this you need to increase the Parameter "Max Faces Show Inner"
EkaitzEsteban
Postby EkaitzEsteban » Fri Sep 21, 2018 2:24 pm
Thank you bernd
bernd
Postby bernd » Tue Sep 25, 2018 11:09 am
Not to forget. If faces are set to be shown the internal of the mesh can only be seen if trancparency is set to somewhat >> 0
bernd
Postby bernd » Tue Sep 25, 2018 11:13 am
The FEM clipping box works with the FEM mesh too. Just the selection of the clipping plane has to be done on a normal part. But this usually exists if there is a FEM mesh.
EkaitzEsteban
Postby EkaitzEsteban » Tue Sep 25, 2018 12:51 pm
Thank you, very interesting for selecting internal nodes
