[Partially solved] Selected element identification in .inp file
bernd
Re: [Help] Selected element identification in .inp file
Postby bernd » Wed Sep 26, 2018 9:24 am
small improvement ...
sel=Gui.Selection.getSelectionEx()[0]
N=len(sel.SubElementNames)
shownode=[]
for i in range(N):
	A=sel.SubElementNames[i]
	newstr = ''.join((ch if ch in '0123456789.-' else ' ') for ch in A)
	newstr_ =" ".join(newstr.split())
	shownode.append(int(newstr_))
Gui.ActiveDocument.getObject(sel.ObjectName).HighlightedNodes = shownode
I can reproduce the problem. I try to have a look.
EkaitzEsteban
Postby EkaitzEsteban » Wed Sep 26, 2018 10:02 am
shownode=[]
for i in range(N):
great!
EkaitzEsteban
Postby EkaitzEsteban » Wed Sep 26, 2018 12:11 pm
Finally I create a first version of a macro for node selection (too much for improving yet).
Once a node is selected, the macro highlights the selected node and also all the nodes from the adjacent elements. It is quite limited but solve a part of my problem. See figure:
I have two more questions:
Is it possible to change the color of the highlighted nodes?
and it is possible to highlight, or change the color of the wireframe?
I check this options by typing in python API:
dir(Gui.ActiveDocument.getObject("FEMMeshGmsh"))
#['Annotation', 'BackfaceCulling', 'BoundingBox', 'Content', 'DisplayMode', 'ElementColor', 'HighlightedNodes', 'IV', 'Icon', 'LineWidth', 'MaxFacesShowInner', 'MemSize', 'Module', 'NodeColor', 'NodeDisplacement', 'Object', 'PointColor', 'PointSize', 'PropertiesList', 'Proxy', 'RootNode', 'Selectable', 'SelectionStyle', 'ShapeColor', 'ShapeMaterial', 'ShowInner', 'Transparency', 'TypeId', 'Visibility', 'VisibleElementFaces', '__class__', '__delattr__', '__doc__', '__format__', '__getattribute__', '__hash__', '__init__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'addDisplayMode', 'addExtension', 'addProperty', 'applyDisplacement', 'claimChildren', 'finishEditing', 'getAllDerivedFrom', 'getDocumentationOfProperty', 'getEditorMode', 'getGroupOfProperty', 'getPropertyByName', 'getTypeIdOfProperty', 'getTypeOfProperty', 'hasExtension', 'hide', 'isDerivedFrom', 'isEditing', 'isVisible', 'listDisplayModes', 'removeProperty', 'setEditorMode', 'setNodeColorByScalars', 'setNodeDisplacementByVectors', 'setTransformation', 'show', 'startEditing', 'supportedProperties', 'toString', 'update']
but I dont know which are callbacks or properties....
Thank you so much for your help!!!
EkaitzEsteban
Postby EkaitzEsteban » Wed Sep 26, 2018 1:10 pm
This still works? https://www.freecadweb.org/wiki/FEM_Mesh
because I am unable to employ this example in my mesh....
Visual handling
Highlight some nodes on the view:
import FreeCAD, Fem
m = Fem.FemMesh()
m.addNode(0,1,0)
m.addNode(0,0,1)
m.addNode(1,0,0)
m.addNode(0,0,0)
m.addNode(0,0.5,0.5)
m.addNode(0.5,0.03,.5)
m.addNode(0.5,0.5,0.03)
m.addNode(0,0.5,0)
m.addNode(0.03,0,0.5)
m.addNode(0.5,0,0)
m.addVolume([1,2,3,4,5,6,7,8,9,10])
Fem.show(m)
Gui.ActiveDocument.ActiveObject.HighlightedNodes = [1,2,3]
Postprocessing colors and displacement: Highlight some nodes on the view:
# set the volume 1 to red
Gui.ActiveDocument.ActiveObject.ElementColor= {1:(1,0,0)}
# set the node 1 and 2 to a certain Color and interpolate the survace
Gui.ActiveDocument.ActiveObject.NodeColor= {1:(1,0,0),2:(1,0,0)}
# set the node 1 and 2 to a certain displacement
Gui.ActiveDocument.ActiveObject.NodeDisplacement= {1:FreeCAD.Vector(1,0,0),2:FreeCAD.Vector(1,0,0)}
# double the factor of the displacement shown
Gui.ActiveDocument.ActiveObject.animate(2.0)
bernd
Postby bernd » Wed Sep 26, 2018 1:27 pm
It should ... I will try to have a look at your questions later on ...
bernd
Postby bernd » Wed Sep 26, 2018 3:49 pm
No not with Python. Do you know C++ ? If you compile FreeCAD it's possible.
No neither highlight nor change color. What is possible on edge meshes is selecting.
As you may see the mesh view provider (the cpp class govern for all your needs) needs some love, because alls your needs are doable but needs some C++ deverlopment.
Bernd
EkaitzEsteban
Postby EkaitzEsteban » Wed Sep 26, 2018 4:06 pm
Hello Bernd,
I tried using a very simple example. Load Cantilever beam 3D from the start page
Gui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").Visibility=True
A=Gui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh")
A.ElementColor={1:(1,0,0)}
I expected to get an element 1 with red color. However, all the mesh becomes green :cry:
Can someone know about that?
bernd
Re: [Help+Bug] Selected element identification in .inp file
Postby bernd » Wed Sep 26, 2018 4:15 pm
Wed Sep 26, 2018 7:26 am
EDIT: I found a BUG. If you select a again the highlighted node. This one is then renamed to Node1.
I try to explain. Use the abovementioned code with solely one node. e.g Node33
If you click again in the highlighted Node33, in the selection view you will see Node1 :shock:
https://forum.freecadweb.org/viewtopic. ... 48#p258746 and issue #3618
bernd
Postby bernd » Wed Sep 26, 2018 4:59 pm
remember volumes of the famous :mrgreen: cantilever starts with 149 thus
A.ElementColor={149:(1,0,0)}
It seams if the element could not be colored all or non (which means all will be green) elements are colored. BTW the code ... https://github.com/FreeCAD/FreeCAD/blob ... #L178-L192 and https://github.com/FreeCAD/FreeCAD/blob ... #L631-L652
bernd
Postby bernd » Wed Sep 26, 2018 7:36 pm
fixed in commit git commit 00bf21d. Sometimes werner is faster in fixing bugs than we in reporting :mrgreen:
