[Partially solved] Selected element identification in .inp file
EkaitzEsteban
Re: [Help] Selected element identification in .inp file
Postby EkaitzEsteban » Thu Sep 27, 2018 6:56 am
bernd wrote:
Wed Sep 26, 2018 4:59 pm
remember volumes of the famous :mrgreen: cantilever starts with 149 thus
Gui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").Visibility=True
A=Gui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh")
A.ElementColor={149:(1,0,0)}
It seams if the element could not be colored all or non (which means all will be green) elements are colored. BTW the code ... https://github.com/FreeCAD/FreeCAD/blob ... #L178-L192 and https://github.com/FreeCAD/FreeCAD/blob ... #L631-L652
Thank you bernd. it partially works.
Maybe I'm digging too much (sorry for my insistence), but I found another bugs or something that it is not compatible.
Here is a bug 1:
The visibility changes If you select show inner true or show inner false. Volumes are partially showed...
FreeCADGui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").ShowInner = False
FreeCADGui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").ShowInner = True
Here is a bug 2:
If you change the display mode to faces + wireframe + nodes
FreeCADGui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").DisplayMode = u"Faces, Wireframe & Nodes"
Several nodes changes their color and not follows the Point color properties, e.g:
FreeCADGui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").PointColor = (0.33,0.33,1.00)
Here is a bug 3:
By changing the colors of the materials the cantilever beam becomes a superstar :P
BTW I have another two question related with this visual handling options:
1-) How can I change the colors of more than one element at the same time? (I think it is not possible...)
2-) How can I return to the original colors of the mesh?
Thank you so much,
best regards,
Ekaitz.
bernd
Postby bernd » Thu Sep 27, 2018 7:51 am
:shock: I knew it before ... The cantilever is the superstar :mrgreen: :lol:
try:
A.ElementColor={149:(1,0,0), 150:(1,0,9)}
A.ElementColor={}
I will try to have a look at all your inputs ...
EkaitzEsteban
Postby EkaitzEsteban » Thu Sep 27, 2018 8:00 am
:shock: I knwew it before ... The cantilever is ths superstar :mrgreen: :lol:
try:
A.ElementColor={149:(1,0,0), 150:(1,0,9)} # Colored two elements
A.ElementColor={} # Returns to the original ones
Awesone! Both code lines works perfectly ;)
EkaitzEsteban
Postby EkaitzEsteban » Thu Sep 27, 2018 2:59 pm
Regarding the visualization of the elements from a mesh. I find another bug or mismatch.
I my mesh two elements are highlighed in red, solely when I selected one.
I do the same in cantilever bean example and looks like correct.
The differences between these two examples is that my box has more than one group (4 exactly), whereas in the cantilever beam the number of groups is 0.
Is there any mismatch here, between color elements and number of groups?
best regards,
Ekaitz.
bernd
Postby bernd » Thu Sep 27, 2018 4:11 pm
It should not have to do with groups. Would you post your mesh an the the code to produce the problem?
EkaitzEsteban
Postby EkaitzEsteban » Fri Sep 28, 2018 6:26 am
Hi bernd,
Yes absolutely,
I make the following:
1-) open SimpleBox.FCStd
2-) Write in the python API: the following code
Gui.ActiveDocument.getObject("FEMMeshGmsh").ElementColor={59:(1,0,0)}
Two different faces are highlighted in red.
Furthermore, I select node 16 which is solely in one element: 59. I double check the position of this node that in the .inp file ['59, 26, 41, 8, 6, 59, 45, 30, 27, 44, 16\n'] --> element 59 is a tetra10 C3D10 type element where the nodes on the 4 vertex of the tetrahedron are 26, 41, 8, 6 respectively, whereas intermediate nodes are the following 6: 59, 45, 30, 27, 44, 16 (The selected one!!!)
So, I guess that element 59 should be highlighted in red, but this is not the case... :cry:
I attach a simple figure of my problem:
best regards,
Ekaitz.
SimpleBox.FCStd
(9.31 KiB) Downloaded 4 times
bernd
Postby bernd » Fri Oct 05, 2018 4:48 am
issue #3624 I'm quite busy ATM, means I did not have the time to have a look at this. Furthermore it is not that easy to tackle down problems in the mesh view provider for me. It takes some time to get into it. I made an issue to keep the problems.
bernd
EkaitzEsteban
Postby EkaitzEsteban » Fri Oct 05, 2018 6:05 am
bernd
Thank you bernd.
The possibility to select nodes is enough for my project (we got it :lol: ). The colors of the elements is only for enhancing the visualization, it is not vital for my project. If it is possible to improve the visualization in future versions of FreeCAD, it would be awesome!
best regards,
Ekaitz.
