Help with install on OS X
lemonbug
Postby lemonbug » Tue Sep 25, 2018 11:51 pm
Hi-
I am trying to install the components for the FEM workbench on OSX.
Following Bernards post: https://forum.freecadweb.org/viewtopic. ... 52#p198642
My question is: subsequent to running this command "brew install calculix-ccx" is something supposed to happen in the terminal window?
I went to /usr/local/Cellar/calculix-ccx/2.13/bin/ccx_2.13 but the dir does not exist. I have up to /usr/local/Cellar/
Thanks, j
OS: Mac OS X
Version: 0.17.13519 (Git)
Branch: (HEAD detached at 1a8b868)
Hash: 1a8b868018f45ea486c0023fdbfeb06febc1fb89
Python version: 2.7.14
Qt version: 5.10.1
OCC version: 7.2.0
lemonbug
Re: Help with install on OS X
Postby lemonbug » Wed Sep 26, 2018 12:00 am
Looks like it didnt install. Here is the latest msg.
Last login: Tue Sep 25 16:37:33 on ttys000
MacBook-Pro:~ j$ brew install calculix-ccx
Error: No available formula with the name "calculix-ccx"
==> Searching for a previously deleted formula (in the last month)...
Warning: homebrew/core is shallow clone. To get complete history run:
git -C "$(brew --repo homebrew/core)" fetch --unshallow
Error: No previously deleted formula found.
==> Searching for similarly named formulae...
Error: No similarly named formulae found.
==> Searching taps...
==> Searching taps on GitHub...
Error: No formulae found in taps.
MacBook-Pro:~ j$
peterl94
Postby peterl94 » Wed Sep 26, 2018 1:47 am
The calculix homebrew formula was in homebrew-science which has been deprecated by homebrew. However, you can still access it from the brewsci fork.
brew tap brewsci/science
lemonbug
Postby lemonbug » Wed Sep 26, 2018 3:44 am
yea! got that part installed now. on to the next step. thanks so much!
Postby chrisb » Wed Sep 26, 2018 5:53 am
Hi lemonbug, could you please note all the steps necessary to get it running? My description seems to be outdated and it would be great if we can have a final contribution here where it is all in one post.
lemonbug
Postby lemonbug » Wed Sep 26, 2018 6:22 pm
Will do. I am trying to work through this tutorial to confirm its working but things are not matching up on my end with whats written.
https://www.freecadweb.org/wiki/FEM_tutorial
lemonbug
Postby lemonbug » Wed Sep 26, 2018 6:51 pm
Ok, I am pretty sure I have it working, I just need to learn how to use it now = ).
Thanks to Bernard and peterl94 and everyone else who worked so hard to get this put together. This is what I did.
I followed Bernard’s post from here: https://forum.freecadweb.org/viewtopic. ... 52#p198642 but made a few changes as outlined below.
Here are the exact steps I took.
1) I installed homebrew see https://brew.sh/
2) Running ’brew install calculix-ccx' in a Terminal window on my Mac now gives you an error message (09-26-18) so I followed the new commands below.
Per peterl94 the new commands to type in the terminal window are:
“brew tap brewsci/science”
“brew install calculix-ccx”
3) Start FreeCAD to setup the binary path of calculiX. I selected FEM workbench. FreeCAD—>Preferences—>FEM in the bottom left, CalculiX tab at the top center, the pasted the path “/usr/local/Cellar/calculix-ccx/2.13/bin/“ in the first field labeled “ccx binary path”.
Screen Shot 2018-09-26 at 11.42.42 AM.png (275.28 KiB) Viewed 642 times
That’s it.
Screen Shot 2018-09-26 at 11.32.35 AM.png (57.19 KiB) Viewed 642 times
lemonbug
Postby lemonbug » Wed Sep 26, 2018 7:39 pm
Looks like I still have an error when running the mech analysis after writing the .inp file. Also, in Bernards post is mentions to put the binary name in the path but it errors out for me when I do so I changed it to "/usr/local/Cellar/calculix-ccx/2.13/bin/" and it at least runs now.
0.0: Check dependencies...
0.1: Write completed.
0.0: CalculiX binary: /usr/local/Cellar/calculix-ccx/2.13/bin/ccx_2.13
0.0: Run CalculiX...
0.0: Starting CalculiX...
0.0: CalculiX stopped.
0.1: CalculiX execute error: PySide2.QtCore.QProcess.ProcessError.FailedToStart
I think I have my model all set up, just can't figure out how to get past that error.
Screen Shot 2018-09-26 at 4.46.58 PM.png (204.45 KiB) Viewed 633 times
