OOFem
bernd
Re: OOFem
Postby bernd » Sun Oct 07, 2018 8:29 am
wow!
Ok, if you go for the implementation, I will help to tackle down all problens you encounter. It can all done in Python. I would highly recomend to base it on the new solver frame work. All needed modules to create an input file and run the solver can be found in directory femsolver. Vtk results can be read directly. I will post some links to the code later on ...
bernd
Re: OOFem
Postby bernd » Sun Oct 07, 2018 8:51 am
check the oldest commits of these ones https://github.com/FreeCAD/FreeCAD/comm ... solver/z88
HarryvL
Re: OOFem
Postby HarryvL » Sun Oct 07, 2018 4:08 pm
wow!
Thanks. I will give it a go.
bernd
Re: OOFem
Postby bernd » Sun Oct 07, 2018 5:18 pm
most important commit ... git commit 609e97a This added Solver Z88 in one commit. Keep in mind a few things have changed since this. For example one hint in the regard of cmake. You only need to add new Python modules once here: https://github.com/FreeCAD/FreeCAD/blob ... eLists.txt
good luck :mrgreen:
bernd
Re: OOFem
Postby bernd » Sun Oct 07, 2018 5:21 pm
best to exchange code would be if you push all your new code to github. With this it is easy to pull and to test your code. In the regard of git and github this may be useful Source_code_management
HarryvL
Re: OOFem
Postby HarryvL » Sun Oct 07, 2018 5:23 pm
...For example one hint in the regard of cmake. You only need to add new Python modules once here: https://github.com/FreeCAD/FreeCAD/blob ... eLists.txt
Ah yes Cmake ... thanks.
HarryvL
Re: OOFem
Postby HarryvL » Sun Oct 07, 2018 7:06 pm
Yup. I already started a new repository for this, i.e. github.com/HarryvL/FC_OOFEM. I will create a branch "assess" for the first baby steps.
PrzemoF
Re: OOFem
Postby PrzemoF » Mon Oct 08, 2018 1:43 pm
How did you make the fork? Manually? I'm not sure if you'll be able to use FreeCAD/github arrangements for pull request testing if that's the case.
My FreeCAD fork header looks like this:
PrzemoF/FreeCAD forked from FreeCAD/FreeCAD
You can use fork button in github to make a fork.
HarryvL
Re: OOFem
Postby HarryvL » Mon Oct 08, 2018 2:10 pm
I pulled freecad/freecad to my local system and then pushed that to my repository. Do I need fork on Github and then pull from there instead?
bernd
Re: OOFem
Postby bernd » Mon Oct 08, 2018 2:13 pm
It would be the smart way!
