FEM and python 3 issues
I think it is an external WB or script...
but i think it is FEM related: https://forum.freecadweb.org/viewtopic. ... 90#p267390
Re: FEM and python 3 issues
no it is not external, it is FreeCAD FEM ...
damn I still have not joined the Py3 party on my Linux dev machine. I will have a look at this with a win py3 dev release of sgrogan.
bernd
bernd
FYI there is a Conda based AppImage available and therefore you don't need Windows to test it.
Is there a way to edit files (.py) in the AppImage? Testing is great, but we are counting on bernd to fix it.
"fight the good fight"
Sure.
downloaded.AppImage --appimage-extract
cd squashfs-root
./AppRun
cd ..
wget "https://github.com/AppImage/AppImageKit/releases/download/continuous/appimagetool-x86_64.AppImage"
chmod a+x appimagetool-x86_64.AppImage
./appimagetool-x86_64.AppImage squashfs-root
all this conda is like git. Once you have undersood it it's simple but if not it not usable at all. Whereas I have understood git, i have not yet understood all this conda ... May be it is because I have not given it a try. I will go for the win way ATM because it only needs 2 minutes to download the image.
bernd
bernd
@triplus wow, very cool! Thanks for sharing
Instructions above are not for using Conda. As AppImage is only based on Conda (packages). Therefore if you will follow the procedure as outlined above on downloaded AppImage:bernd wrote: ↑Thu Nov 08, 2018 7:27 am all this conda is like git. Once you have undersood it it's simple but if not it not usable at all. Whereas I have understood git, i have not yet understood all this conda ... May be it is because I have not given it a try. I will go for the win way ATM because it only needs 2 minutes to download the image.
bernd
cd squashfs-root
You don't have to understand anything about Conda (or AppImage). You can start modifying .py files and test the changes by starting FreeCAD (located in the squashfs-root folder):
./AppRun
You're welcome.
wow that sounds gread! but I need to install some package on my debian, do I? Which one, there is no package called appimage on debian stretch.triplus wrote: ↑Thu Nov 08, 2018 11:14 pmInstructions above are not for using Conda. As AppImage is only based on Conda (packages). Therefore if you will follow the procedure as outlined above on downloaded AppImage:bernd wrote: ↑Thu Nov 08, 2018 7:27 am all this conda is like git. Once you have undersood it it's simple but if not it not usable at all. Whereas I have understood git, i have not yet understood all this conda ... May be it is because I have not given it a try. I will go for the win way ATM because it only needs 2 minutes to download the image.
https://github.com/FreeCAD/FreeCAD/releasesCode: Select all
downloaded.AppImage --appimage-extract cd squashfs-root
Mentioned procedure doesn't modify your environment in any way. That is nothing gets installed and no environment paths get modified.Code: Select all
./AppRun
