FEM Thermal Analysis of a PCB: a new challenge
Re: FEM Thermal Analysis of a PCB: a new challenge
Also my 2 cent.
- To simulate such PCBs in a meaningful way we need convection
-- Convection is available as boundary-condition in calculix (also done in simscale) but not jet implemented in freecad. I somehow remember that this boundary condition is not really accurate but do not have any link for that now (maybe in the simcale forum). A comparison with a detailed navier-stokes simulation including convection would here be really helpfull.
-- In Elmer convection is available but as I remember only in combination with the navier stokes when also simulating the air around the PCB. I do not know if a steady state simulation of convection is available.... as I remember it always has to be a transient simulation which consumes huge amounts of memory and time .
Please note also that there is a inconvenience regarding the definition of the the dissipated energy of body heat sources which has to be inserted as fraction with the density of the domain. I am not sure if all needed elements currently are available in FC. EDIT: Please see also https://forum.freecadweb.org/viewtopic. ... hilit=heat
-- CfdOF could be an alternative to elmer if it is possible to introduce proper heat-sources.
I currently do have only a very very limited time budget for FC-FEM but really hope to see some solution in this regard of a better collaboration between FreeCAD and KiCAD.
All the best.
BR,
HoWil
All the best.
BR,
HoWil
Here is a calculation (thermomechanical) with elmer:
http://www.nic.funet.fi/index/elmer/doc ... orials.pdf
but the elmer-GUI does not work properly. Cant select any surface.
I tried the pump tutorial fromhttp://www.nic.funet.fi/index/elmer/doc ... orials.pdf
Hi Thomas,
I downloaded your FC file but I cannot display the FEMMeshGmsh...
If I toggle the visibility of the compound, I cannot display the FEMMeshGmsh mesh object... and then I cannot run any analysis...
Is there a bug in FC when saving the file or am I missing some basic step?
I mean it seems the meshing is not available inside the file...
I'm a real noob in FEM, but I tried the Cantilever example and it works on my FC installation...
Here my FC info:
Version: 0.18.15190 (Git)
Hash: c18785fdb31e378500440de23dcf648a2c79dc5f
Python version: 2.7.14
OCC version: 7.2.0
Hi Maurice,
load my file in FC. Then:
Doubleclick on Analysis in tree ==> FEM-wb is activated.
Doubleclick on mesh in tree ==> meshing dialog opens, click apply to remesh the body
Run analysis
After meshing the body, right click on mesh in tree. You will see the option "clear mesh".
This can be used to reduce the file size (< 1 MB) for posting in the FC-forum. Which I did...
Thomas
Thx a lot! now it worksthschrader wrote: ↑Thu Dec 06, 2018 10:26 am Hi Maurice,
Run analysis
Thomas
Next step is trying the Elmer model...
Hi Thomas,
I'm testing the Elmer using 'C:\Program Files (x86)\Elmer 8.3-c30fff2' downloaded here:
https://sourceforge.net/projects/elmerf ... Installer/
but during the solver analysis FC is crashing without any message...
OCC version: 7.2.0
BTW the FC conda release has a py3 issue
File "C:\FreeCAD\Mod\Fem\femsolver\solverbase.py", line 79, in setEdit
machine = run.getMachine(vobj.Object)
File "C:\FreeCAD\Mod\Fem\femsolver\run.py", line 54, in getMachine
_DocObserver.attach()
File "C:\FreeCAD\Mod\Fem\femsolver\run.py", line 334, in attach
cls._instance = cls()
File "C:\FreeCAD\Mod\Fem\femsolver\run.py", line 326, in __init__
for doc in App.listDocuments().itervalues():
<class 'AttributeError'>: 'dict' object has no attribute 'itervalues'
here a detailed Fc log file, related to the FEM crash:
It seems something related to multi threads
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Loading Fem module... done
Log: Loading GUI of Fem module... done
Log: Start: ViewProviderFEMMeshBuilder::createMesh() =================================
Log: 0.000000: Start build up 39744 face helper
Log: 0.015000: Start eliminate internal faces SIMPLE
Log: 0.937000: Start build up node map
Log: 0.937000: Start set point vector
Log: 0.937000: Start count triangle size
Log: NumTriangles:27096
Log: 0.937000: Start build up triangle vector
Log: 0.968000: Start build up edge vector
Log: NumEdges:40284
Log: 0.968000: Finish =========================================================
Log: 0.016000: Start eliminate internal faces SIMPLE
Log: 0.922000: Start build up node map
Log: 0.922000: Start set point vector
Log: 0.922000: Start count triangle size
Log: 0.922000: Start build up triangle vector
Log: 0.953000: Start build up edge vector
Log: NumEdges:40284
Log: 0.953000: Finish =========================================================
Msg: Prepare testmode: FalseMsg:
Msg: ElementDimension: 3Msg:
Msg: C:/FreeCAD-daily/bin/gmsh.exe
Msg:
Log: FEM mesh object will be exported to unv format.
Log: QPixmap: It is not safe to use pixmaps outside the GUI thread
Wrn: Cannot find icon: TextDocument
Log: QObject::startTimer: timers cannot be started from another thread
Log: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QTextDocument(0x25234a23eb0), parent's thread is QThread(0x25234a1ca50), current thread is QThread(0x25213f705d0)
