Concrete branch ready for testing
Re: Concrete branch ready for testing
Thanks Bernd. This works. To give it a test I simply selected "Concrete Generic" for the matrix and "Calculix Steel" for the reinforcement. I then edit the material and enter yield strength for the reinforcement material and friction angle for the matrix material. The yield strength sticks (turning the "Calculix Steel" into "_Transient_Reinforcement_Material"), but the "Concrete Generic" remains unchanged and the friction angle is not captured).
If I then change Concrete Generic to Concrete-Harry everything works well, but again I cannot change the friction angle from the default value of 30 degrees.
Any idea what is causing this, Bernd?
good test, this should work. I will have a look .
Test of a concrete shear wall 3m wide by 1m high and 0.15m thick loaded by a distributed load of 0.75 MN at the top. Both sides are fully fixed, as if the wall is part of a larger inflexible structure:
I make use of symmetry at the center line of the beam and only model half of the problem. Maximum reinforcement ratios are rx = 5.8%, ry = 1% and rz = 2.3%, respectively:
... using this result and a minimum percentage of 0.3% in all directions I then loaded the wall to destruction
Principal parameters used in the analysis:
yield strength steel = 315.0 MPa
compressive strength concrete = 15.75 MPa
friction angle = 30.0 degrees
dilation angle = 0.0 degrees
material: Mohr-Coulomb
tension cut off: principal stress
tension strength concrete = 0.0 MPa
reinforcement ratio: automatic from elastic analysis
minimum reinforcement ratio = 0.003
If I input 30 deg into the friction angle it works great for me! What exactly did you put in friction angle?HarryvL wrote: ↑Sat Jun 08, 2019 5:15 pm To give it a test I simply selected "Concrete Generic" for the matrix and "Calculix Steel" for the reinforcement. I then edit the material and enter yield strength for the reinforcement material and friction angle for the matrix material. The yield strength sticks (turning the "Calculix Steel" into "_Transient_Reinforcement_Material"), but the "Concrete Generic" remains unchanged and the friction angle is not captured).
great pics. Everything else seam to work. Means if we solve the friction angle problem we can go for a merge
I put 30 degrees into Concrete Generic. Close/open and it’s gone. Also the name of the material object should change when you change a parameter, right? I will try again.
put in
30 deg
harry your opinion is very welcome on https://forum.freecadweb.org/viewtopic.php?f=34&t=36856
I might have ask this before ...
https://github.com/berndhahnebach/FreeC ... ls.py#L573 scxx, scyy, sczz are not used in the def, why are they parameters?
