Concrete branch ready for testing
bernd
Re: Concrete branch ready for testing
Post by bernd »
the concrete beam is a bit better ...
HarryvL
Post by HarryvL »
I don’t have access to my computer. Will send as soon as I can. However, I don’t think the VTK is the problem, but rather your glyph filter settings. There are a few places you need to check: the type (chose line), the source (=PSV3Vector for compression), the scaling (press the rescaling icon to the right of the scale factor, the locations (choose all points) and the color (whatever you like).
HarryvL
Post by HarryvL »
See attached:
TestCubePrincipalStress_vtk.txt
(77.45 KiB) Downloaded 36 times
HarryvL
Post by HarryvL »
Set the Representation for TestCubePrincipalStress.vtk to Wireframe and take the glyph settings as in the picture. Pay attention to the following parameters:
Glyph Source
Orientation
Scale
Masking
HarryvL
Post by HarryvL »
And looking at your concrete example, I think scale and orientation are not selected correctly.
bernd
Post by bernd »
mhh my glyph properties look totally different from yours ... I have paraview 5.4.1 on Debian Buster ...
bernd
Post by bernd »
ok I get your picture, but not because I know what I am doing but because I pressed buttons as long until the picture looks like yours ...
HarryvL
Post by HarryvL »
Great, that’s how I learnt using Paraview :D
By the way, I use the latest Paraview binary from the Kitware web site, 5.6.0 to be precise.
HarryvL
Post by HarryvL »
By the way, if you press the gear wheel near the top of the property box you get to see more options. Then your property screen will most likely look the same as mine.
bernd
Post by bernd »
HarryvL wrote: Sun Jan 06, 2019 7:40 pm By the way, if you press the gear wheel near the top of the property box you get to see more options. Then your property screen will most likely look the same as mine.
:D
