Concrete branch ready for testing
bernd
Re: Concrete branch ready for testing
Postby bernd » Tue Mar 26, 2019 10:25 pm
bernd
Postby bernd » Wed Mar 27, 2019 12:11 am
EDIT:
Attached your example with reinforced material ... you will need my latest branch ... The concrete node search is name independent too ... There is an icon to add a reinforcement material. For the material parameter Python is needed, some is attached ... We will need a task panel, but first it needs to run ...
edit by python:
matrixprop = {}
matrixprop['Name'] = "Concrete"
matrixprop['YoungsModulus'] = "32000 MPa"
matrixprop['PoissonRatio'] = "0.17"
matrixprop['CompressiveStrength'] = "15.75 MPa"
matrixprop['AngleOfFriction'] = "0.52333"
reinfoprop = {}
reinfoprop['Name'] = "HarrysReinforcement"
reinfoprop['YieldStrength'] = "315 MPa"
reinfoprop['ReinforcementRatio'] = "0.0"  # not an official FreeCAD material property
App.ActiveDocument.ReinforcedMaterial.Material = matrixprop
App.ActiveDocument.ReinforcedMaterial.Reinforcement = reinfoprop
edit by material editor
import MaterialEditor
# matrix material
props = App.ActiveDocument.ReinforcedMaterial.Material
props = MaterialEditor.editMaterial(props)
if props:
    App.ActiveDocument.MaterialReinforced.Material = props
# reinforcement
props = App.ActiveDocument.ReinforcedMaterial.Reinforcement
if props:
    App.ActiveDocument.MaterialReinforced.Reinforcement = props
show the material properties:
Wall_2D.FCStd
(49.43 KiB) Downloaded 3 times
bernd
Postby bernd » Wed Mar 27, 2019 1:59 am
testing is highly appreciated
HarryvL
Postby HarryvL » Wed Mar 27, 2019 6:37 am
Bernd, your example file has an object MaterialReinforced and your Python script refers to an object ReinforcedMaterial.
When I change your Python scripts to the ones below then the input goes well, but then I get the following error when running CCX:
EDIT: ah this is because I didn't specify a CCX working directory. This was never a problem before?! It would normally default to TMP.
Apart from that everything seems to work.
Executing solver...
 *ERROR in openfile: input file FEMMeshGmsh.inp
 does not exist
and
Exception in thread Thread-11:
  File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
    self.run()
  File "/usr/lib/python2.7/threading.py", line 754, in run
    self.__target(*self.__args, **self.__kwargs)
  File "/home/harry/FC_Dev/Build/Mod/Fem/femsolver/task.py", line 115, in protector
    self.run()
  File "/home/harry/FC_Dev/Build/Mod/Fem/femsolver/calculix/tasks.py", line 126, in run
    self.load_results_ccxfrd()
  File "/home/harry/FC_Dev/Build/Mod/Fem/femsolver/calculix/tasks.py", line 138, in load_results_ccxfrd
    self.directory, _inputFileName + '.frd')
  File "/usr/lib/python2.7/posixpath.py", line 70, in join
    elif path == '' or path.endswith('/'):
AttributeError: 'NoneType' object has no attribute 'endswith'
matrixprop = {}
reinfoprop = {}
App.ActiveDocument.MaterialReinforced.Material = matrixprop
App.ActiveDocument.MaterialReinforced.Reinforcement = reinfoprop
# matrix material
props = App.ActiveDocument.MaterialReinforced.Material
if props:
# reinforcement
props = App.ActiveDocument.MaterialReinforced.Reinforcement
if props:
HarryvL
Postby HarryvL » Wed Mar 27, 2019 6:41 am
By the way,
it feels more natural to enter angles in degrees than in radians. You can always transform them in the code: angle_in_rad = PI()/180 * angle_in_degree
bernd
Postby bernd » Wed Mar 27, 2019 7:25 am
FreeCAD FEM does no longer just create non existing user specified directories. The user has to take care on this. Is this annoying?
HarryvL
Postby HarryvL » Wed Mar 27, 2019 7:38 am
Nope. It’s ok. But it would be good to stop people when they don’t enter a directory rather than crash in CCX.
bernd
Postby bernd » Wed Mar 27, 2019 8:03 am
By the way,
FreeCAD can do this for us. The unit system is very very cool once one get used to it.
            matrix_af = float(FreeCAD.Units.Quantity(obj.Material['AngleOfFriction']).getValueAs('rad'))
https://github.com/berndhahnebach/FreeC ... cc4d671354
the new material code ...
matrixprop = {}
matrixprop['AngleOfFriction'] = "30 deg"  # make some hint on the possible angle units in material system
reinfoprop = {}
bernd
Postby bernd » Wed Mar 27, 2019 8:08 am
Mhh we gone use the new solver because has no pre checks at all. Thus he does not claim about we are not having a material in our analysis (the new reinforced material needs to be implemented in the pre checks.). Thus he does not claim about if we gone miss some other stuff. This is the main reason for not using the new solver frame work for any normal analysis because there are nearly no pre checks at all. One really misses such a comfortable pre check system once it is not available anymore :lol:
HarryvL
Postby HarryvL » Wed Mar 27, 2019 6:40 pm
Something not right yet:
  File "/home/harry/FC_Dev/Build/Mod/Fem/femguiobjects/_ViewProviderFemSolverCalculix.py", line 237, in calculixFinished
    self.fea.load_results()
  File "/home/harry/FC_Dev/Build/Mod/Fem/femtools/ccxtools.py", line 830, in load_results
  File "/home/harry/FC_Dev/Build/Mod/Fem/femtools/ccxtools.py", line 840, in load_results_ccxfrd
    importCcxFrdResults.importFrd(frd_result_file, self.analysis, result_name_prefix)
  File "/home/harry/FC_Dev/Build/Mod/Fem/feminout/importCcxFrdResults.py", line 110, in importFrd
    res_obj = restools.add_principal_stress_harry(res_obj)  # fill harrys calculated result values
  File "/home/harry/FC_Dev/Build/Mod/Fem/femresult/resulttools.py", line 385, in add_principal_stress_harry
    print(matrix_af)
UnboundLocalError: local variable 'matrix_af' referenced before assignment
Simple_Block_2.FCStd
(32.11 KiB) Downloaded 3 times
OS: Ubuntu 16.04.5 LTS
Version: 0.19.16225 (Git)
Build type: Unknown
Branch: femconcrete
Hash: 6b861b1bc7712ba4fa26009cb3d081e7a28ea593
Python version: 2.7.12
OCC version: 7.1.0
