feature: general initial value and body source, to be tested
qingfeng.xia
Re: feature: general initial value and body source, to be tested
Postby qingfeng.xia » Mon Feb 24, 2020 11:16 pm
that is silly error, should be x- y- z-component.
I also have another way to input vector, just as C++ constraint type (direction + mag), I have not fully tested, could be added in the future
bernd wrote:
Sun Feb 23, 2020 3:36 pm
https://github.com/berndhahnebach/FreeC ... get.py#L96
            self.componentLabels = ["x-component", "x-component", "x-component"]
Why three times x-component?
Ubuntu 18.04 LTS 64bit, python3, always work with latest FreeCAD daily build
Currently I mainly work on OpenFOAM + Fenics for CFD, FSI
https://github.com/qingfengxia/FreeCAD_Mod_Dev_Guide
https://github.com/qingfengxia/Cfd
qingfeng.xia
Postby qingfeng.xia » Mon Feb 24, 2020 11:18 pm
bernd wrote:
Mon Feb 24, 2020 8:55 pm
IMHO it shoudl be named FemConstraintGeneric instead FemGenericConstraint
It should be easy to just do find and replacement. I will do it later.
I am stuck on the json serialization error.
qingfeng.xia
Postby qingfeng.xia » Sat Feb 29, 2020 9:46 pm
A new PR has been sent to your fembodyconstraint branch. I pull your branch on Tuesday, it still show merge conflict, not sure why.
1. Class rename
2. Json serializable error fixed
bernd
Postby bernd » Sun Mar 01, 2020 6:11 am
great, nevermind about the merge conflict ...
bernd
Postby bernd » Tue Mar 10, 2020 7:08 am
which part of the code does fix this erro ? I run into the same problem https://forum.freecadweb.org/viewtopic.php?f=18&t=44021
bernd
Postby bernd » Tue Mar 10, 2020 9:15 am
merged your code and did myself some code formating and renaming to fit all generic constraint code in FEM code conventions. https://github.com/berndhahnebach/FreeC ... 5bb5176d65 in branch https://github.com/berndhahnebach/FreeC ... constraint
The Json serializable error still resists ... :(
https://github.com/FreeCAD/FreeCAD/comp ... 5bb5176d65 (all changes so far)
bernd
Postby bernd » Tue Mar 10, 2020 7:07 pm
see here for more information https://forum.freecadweb.org/viewtopic.php?f=18&t=44021
bernd
Postby bernd » Tue Mar 10, 2020 7:17 pm
qingfeng.xia
Postby qingfeng.xia » Wed Mar 11, 2020 10:51 pm
add those 2 dumb functions to viewprovider class, in addition to _FemConstraintGeneric.py class. It fixed json error for me.
This solution is aslo form FreeCAD forum.https://forum.freecadweb.org/viewtopic. ... 94#p373094
src/Mod/Fem/femguiobjects/_ViewProviderFemGenericConstraint.py
    def __getstate__(self):
        return None
    def __setstate__(self,state):
        return None
I read your latest branch, you have deleted those 3 functions from _FemConstraintGeneric.py
    def execute(self, obj):
        ''' Called on document recompute '''
        return
        # Called during document saving
        return self.Type
    def __setstate__(self, state):
        if state:
            self.Type = state
Those 3 functions should be taken back. and also some comment to protect those dumb functions , not to be deleted in the future.
bernd
Postby bernd » Thu Mar 12, 2020 6:03 am
no they need not! Everything should work fine so far! They where missing in the superclass!
Would you give it a try?
