Hello everyone,
I am new to FEM simulations and I got started using the Fenics solver. I want to use FreeCad to model the geometry of my simulations and create the mesh. However, I basically ran into the following problem: Assume I want to create a domain D which consists of multiple subdomains D1,D2,D3 (see also body.png), is there a way (Macro etc.) to get a list of the vertices contained in a certain subdomain? Let's say I want to have the numbers of all mesh-vertices which are contained in the half-sphere of the body shown in body.png, is there a way to get access to a list containing these vertices numbers?
(In the example shown, it would of course be possible to test for each vertex programmatically if it lies in the subdomain of interest since the geometry is simple but I am looking for a general way of obtaining the vertex-numbers of subdomains)
Thanks!
Getting the vertice numbers of a subset of vertices
- domains.fcstd
- (81.96 KiB) Downloaded 23 times
- body.png (132.2 KiB) Viewed 390 times
Re: Getting the vertice numbers of a subset of vertices
strange geometry ... See tree view the cube material_0 and material_02 is the same cube ...
- Screenshot_20190101_201606.png (493.35 KiB) Viewed 373 times
BTW your CompSolid has four solids, the right cube, the left cube without downside half sphere, the downside half sphere and the upper half sphere. If you only would like to have three you should only use three solids ...
